Other Stuff > Misc / Open
Electrical connections.
K2-K6:
Silicone grease onto all the contact /voids.
Doesn't conduct, so no benefits in that direction, but with almost complete absence of any moisture during use, they stay in pristine condition.
It won't affect plastics or rubber either.
BigAl (Alan):
The 6.3mm terminals/connectors are very robust, just keep them clean & dry.
ST1100:
I treat all electrical connectors with a whiff of ACF-50... spray, or distribute a small amount with a Q-tip, whatever the situation requires...
https://www.acf-50.eu/acf-50
Brilliant results...
Handlebar switch-pods, ignition lock switch-plates, bullet- or multi pin connectors, relay & bulb sockets... (even the PCB inside the face-plate of the Sony stereo on my ST1100...)
Skoti:
--- Quote from: BigAl (Alan) on January 23, 2025, 11:33:30 AM ---The 6.3mm terminals/connectors are very robust, just keep them clean & dry.
--- End quote ---
Aye,
I agree.
Clean and dry is best, spray stuff attracts unwanted dust and dirt to stick.
Spitfire:
When I cleaned up my wiring harnes all the connectors were cleaned and then coated with dielectric (silicone) grease, never had a problem.
Navigation
[0] Message Index
[*] Previous page
Go to full version
