SOHC.co.uk Forums > CB750
bearing shells
Sesman:
It tells me your big ends are fooked!
Bryanj:
Not necessarily, the clearance is less than 7 thou but until the correct stuff is used we dont know the clearance.
You need to used Red plastigauge not green
McCabe-Thiele (Ted):
The wider the squash the tighter the bearing clearance.
K2-K6:
Looks approx 3 1/5 thou (0.088 mm) from that assessment.
Iirc the Plastgauge I used was in a green package.
It was marked as 0.001-0.003".
0.025 - 0.076 mm.
Not sure if that is correct for your engine. Someone here will correct me if I'm mistaken.
Navigation
[0] Message Index
[*] Previous page
Go to full version
