Try our new info resource - "Aladdin's Cave" (Main menu)Just added a separate link to Ash's Dropbox thread (shortcut)
Thank you all for your help, looks like the Cteck and Optimate are the winners, I will need to buy another two (one for the mini and one for a Kawasaki but this one is 6v). :-)
I used a trickle charger like that back in the 1990s on my Yamaha, I did have to check the acid levels more often. If money is tight a cheap option. Smart Chargers are pretty clever being multifunctional, some have a recovery function for lightly sulphonated batteries as well as pulse maintainable electronics that monitor voltage.
Quote from: neat street on February 09, 2025, 09:03:57 AMThank you all for your help, looks like the Cteck and Optimate are the winners, I will need to buy another two (one for the mini and one for a Kawasaki but this one is 6v). :-)As an alternative (different use and simple) as supplement etc, this https://www.ebay.co.uk/itm/172324102119 type ive used for years reliably, very slow trickle, maintains or slowly charges fine, only one switch for 12/6 volt select. The discount code listed on site works too in reduction of cost.I'm not suggesting as replacement for those good smart chargers above,, but a good and very simple accompanying item that'll do both volts.
