Author Topic: Gearchange rod  (Read 4266 times)
Offline XS850
Gearchange rod
« on: March 05, 2025, 11:02:14 AM »
Hi All, I’ve misplaced the gearchange adjusting rod so need to make a new one (originals -new - not available).
Can someone kindly give me the measurements please? Total length, thread diameter (6mm? LH & RH thread?) and rod diameter?
Many Thanks - Bruce
Re: Gearchange rod
« Reply #1 on: March 05, 2025, 06:22:43 PM »
For which motorcycle!?
Offline Seabeowner
Re: Gearchange rod
« Reply #2 on: March 05, 2025, 06:32:32 PM »
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
Offline XS850
Re: Gearchange rod
« Reply #3 on: March 05, 2025, 06:50:51 PM »
Sorry - CB400F.
Seabeowner - yes, that one but nowhere available!
Cheers - Bruce
Online McCabe-Thiele (Ted)
Re: Gearchange rod
« Reply #4 on: March 05, 2025, 07:11:18 PM »
I've sent you a PM.
Re: Gearchange rod
« Reply #5 on: March 05, 2025, 10:17:11 PM »
I have measured my old link rod with a set of calipers, I'm pretty sure it was the original one.
Total rod length is 61 mm, the shaft diameter is 7.8 mm.
Left hand M6 thread at the gearbox end - the threaded section is 15.0 mm long.
Right hand thread M6 pitch 1.0 at the shift pedal end - the threaded section is 15.0 mm long.
The main center unthreaded section is 26.0 mm with a taper at each end down to the thread that is about 2.5 mm at each end.
26+15+2.5+15+2.5=61
.PXL_20250305_220619739 by Macabe Thiele, on Flickr
« Last Edit: March 05, 2025, 10:20:56 PM by McCabe-Thiele (Ted) »
Offline XS850
Re: Gearchange rod
« Reply #6 on: March 05, 2025, 10:28:59 PM »
That’s brilliant Ted - many thanks, exactly what I need!
Cheers - Bruce
