SOHC.co.uk Forums > Anorak's Corner
Flushing old fuel
<< < (2/2)
DomP:
To derust i was going to use phosphoric acid
Laverda Dave:
Or DEOX-C, it's great stuff👍.
McCabe-Thiele (Ted):
--- Quote from: DomP on April 06, 2025, 11:27:32 AM ---To derust i was going to use phosphoric acid
--- End quote ---
I've just been de-rusting a pair of exhaust brackets  on my Superdream ( Evaporust is expensive).
I've tried some warm Citric Acid instead, pleased with the results. I found agitation with a brush was needed.
Athame57:
--- Quote from: DomP on April 06, 2025, 09:37:23 AM --- I've never smelt old fuel this foul before.
--- End quote ---
You havn't met up with the Bunker oil they use to fuel merchant ships! It is like a gas attack when the smell is released for whatever reason, intensely reeks of rotten eggs for a start,  :o I once fled my cabin with some bedding and joined others at the opposite end of the ship!   ;D
Bryanj:
Good old heavy fuel oil, used to run 150 ton per day on one ship. Wont burn till heated up
Navigation
[0] Message Index
[*] Previous page
Go to full version
