Try our re-instated info resource - "Aladdin's Cave" (Main menu)- sorry it's taken so long to fix
Or if you're lucky and it's possible to hold the broken stud with vice grips, then apply a wee bit heat and it might just come out.
Correct alignment is essential to prevent the drill bit going off centre.
If someone put it in with red locktite the heat should break it's grip.
Is any of the stud projecting??
Depending on the outcome it might be more cost effective to find a used replacement.
