Author Topic: I need an internal throttle!  (Read 8258 times)
« on: November 27, 2010, 06:11:28 PM »
Internal throttles (twistgrip) ......anyone got one, used one, know where I can find one?  (and I'm thinking old bike stuff, not hugely expensive custom built ones).
I know that old bikes like '40's Indians had these. I also read somewhere online that there are a couple of Hondas that had them but I've certainly never noticed one. So, does anyone know if there are any out there from a factory model?
Offline flc
Re: I need an internal throttle!
« Reply #1 on: November 27, 2010, 06:48:08 PM »
c50/70/90 and some early 70's cb125 twins. there must be more but thats all im sure of.
76 cb 550 import
gpz 1100 chop
z9 chop
sr 125 yam
« Reply #2 on: November 28, 2010, 08:32:17 PM »
I've also seen them on C90 and seem to recall one on a CD175 twin about 1976 year.
« Reply #3 on: November 29, 2010, 05:44:18 AM »
Yep to all the above but they are special handlebars to work it
Offline florence
« Reply #4 on: November 29, 2010, 08:47:27 AM »
The twist grip actions you are thinking of have a slot cut into the handlebars and a shuttle which moves in it.  I imagine your handlebars could be adapted but the slot would have to be very accurate otherwise the throttle would stick.  I don't think it would be worth the trouble for a bike that one would actually want to ride.
The throttle on my Indian was on the left-hand side, with the clutch being operated by foot and a hand gear lever next to the petrol tank; very strange beast to ride.
« Reply #5 on: November 29, 2010, 10:41:26 AM »
I found this diagram online - it's a Honda C90 throttle assembly and shows the slots required in the handlebar. These bars look as if they are square too. I'm going to try & source one to see if I can make it work, but probably be more academic than for real use.
I've previously mocked up one from a piece of copper pipe (in place of a bar) but as it's rather soft & not that easy to work with it ended up being very sticky & not that usable. It gave me some insight into cutting slots in round bar though.
I also found a thread that says these twistgrips only open about 3/4 of the way....so there might be a loss of top-end....or high tick-over.
Offline Dave M
« Reply #6 on: November 30, 2010, 07:17:44 AM »
I had one on my CB125S and found that you needed 2 handfuls of throttle to get it fully open. It was quite stiff too.
Dave
Melbourne.
Offline Yoshi823
  • Biker to the bone...
« Reply #7 on: November 30, 2010, 01:15:52 PM »
Wasn't this called a 'suicide clutch' ?
Bikes...they're in the blood.
Yamaha R1 2001
Yamaha FZR1000R EXUP 1990
KTM 450 EXC RFS 2004
Honda XR400R 1997
Honda CB125T2 1980
Yamaha FJ1200 3XW 1991
Offline florence
« Reply #8 on: November 30, 2010, 03:59:21 PM »
Not sure, but certainly difficult to get used to.  Probably brilliant on those long straight US highways but awkward off-road.
