Author Topic: Front Fork Lower Allen Bolt  (Read 10358 times)
Offline JEZZAIRONBRIDGE
« on: July 28, 2025, 12:58:15 PM »
Hi.
Just a quick question.
Is there a set Torque for the Lower Hexagon (Allen Key) Bolt?
Can't seem to find the setting, if there is one.
Many thanks.
Re: Front Fork Lower Allen Bolt
« Reply #1 on: July 28, 2025, 01:19:53 PM »
Generic 8mm bolt in manual, use new copper washer
Offline Athame57
« Reply #2 on: July 28, 2025, 01:53:14 PM »
I just checked on CMSL, part # 90116283010 is an 8mm allen bolt. Assuming Jezza means the one that secures the seat of the internal pipe.
« Last Edit: July 28, 2025, 01:57:48 PM by Athame57 »
1978 CB400F2 named Elen.
« Reply #3 on: July 28, 2025, 02:03:27 PM »
Hex head external or internal allen its still 8mm so generic torque unless specified different
Offline Athame57
« Reply #4 on: July 28, 2025, 02:12:30 PM »
Maybe there is no official torque setting. Looking at the reccomended tool for the job, it doesn't seem to lend itself to onne.
« Reply #5 on: July 28, 2025, 03:35:23 PM »
Yup but square drive hex keys were not common when the manual was written, now they are easy to get, even long ones from at least snap on
Online exvalvesetdabbler
« Reply #6 on: July 28, 2025, 04:20:07 PM »
I have just used a hand impact driver and a few taps with a hammer to nip them up.
Regarding the copper washers, just rub them over a flat surface with 600 wet'n'dry to clean and heat to red colour with a blow torch to anneal them Never had one leak so far.
Regards
Dave
Offline Athame57
« Reply #7 on: July 28, 2025, 06:45:32 PM »
I think, if I remember right from Nurse Julies rebuild that replacing the allen bolt can be a pain because the pipe is reluctant to recieve and needs to be restrained or something to prevent rotation?
« Reply #8 on: July 28, 2025, 07:39:14 PM »
You're right George, there's nothing so stop it spinning round inside other than a small amount of friction, hence the need for a rattle gun or impact driver.  It's the same when it comes to undoing them, about half a turn and the whole lot just spins round.
Regards
Dave
« Reply #9 on: July 28, 2025, 08:14:04 PM »
Thanks all for information.
Looks to be interesting re build.
« Reply #10 on: July 28, 2025, 09:06:27 PM »
I pushed a length of wooden broom handle down the sanction to compress the spring tight against the damper to stop it turning.
Make sure the seat where the copper washer sits is absolutely clean, being so close to the road it gets a lot of muck thrown at it.
« Reply #11 on: July 28, 2025, 10:59:09 PM »
My method was a little less dignified.
Clamped the slider in a B&D workmate so that it's feet were held  quite a way off the floor and then sat on the workmate with the slider between my legs compress the spring. Then hammered away at the impact driver taking care not to miss.
Regards
Dave
« Reply #12 on: July 29, 2025, 03:23:08 PM »
Fork Seal fitment.
I am replacing Seals that have previously been replaced.
Need to be sure I am fitting them correct way up, or down.
If previously fitted wrong would like to be sure I am now fitting them correctly.
Can you advise how to tell.
Many thanks.
« Reply #13 on: July 29, 2025, 03:47:55 PM »
The open side with the spring visible goes down
« Reply #14 on: July 29, 2025, 03:55:14 PM »
My new Honda Seals have Seals inner and outer
Part number 91255 413 881 from D. Silver.
