CB750
First Start Attempt – K4 Project (Advice Welcome!)
Topic: First Start Attempt – K4 Project (Advice Welcome!) (Read 9231 times)
Yuppie_88 (Luke)
Newbie
July 29, 2025, 09:49:01 PM »
Hi everyone,
I’m getting close to attempting the first proper start on my K4. I bought it as a non-runner from DK Motorcycles - it did fire briefly on Easy Start at the time. I’m a novice, but really enjoying the learning process and taking my time with it.
Before I hit the starter, I’d really appreciate any advice or tips from those with more experience. Here’s what I’ve done so far:
• Loom and electrics overhauled
• New battery
• New plugs (checked the spark across all four cylinders)
• Carbs fully rebuilt
• Cam chain tensioner adjusted
• Fresh oil in (I’ve held off on the filter for now - planning to get it warm, then dump the oil and do a full service)
My main concern at this point is making sure the oil is circulating properly on first start and how to check - though I’m sure there are other things I might be missing too.
Any input or suggestions before I go for it would be hugely appreciated. Thanks in advance!
Re: First Start Attempt – K4 Project (Advice Welcome!)
July 29, 2025, 10:06:09 PM »
Remove the plugs and spin over till the oil light goes out.
Remove tank and all tappet caps and inspect inside for oil flow, even leave off for first start and watch for oil spraying out
Spitfire
July 30, 2025, 10:08:49 AM »
Bryan has nailed it, be patient though, mine took ages for the oil light to go out, I started to suspect it was duff and was tempted to start it up but thankfully did not in the end.
Johnny4428
July 30, 2025, 04:49:06 PM »
I remember putting mine on side stand and filling lower oil gallery. As Dennis says it will take a bit of turning over to fill up all oil ways before getting pressure.
Yuppie_88 (Luke)
Newbie
July 31, 2025, 09:08:43 AM »
Thanks everyone, I wouldn't have thought of this - super helpful.
The fresh oil was added around 10 months ago, I've noted that the oil tank level has dropped considerably (no visible oil leaks). I'm assuming this is because the oil has now worked it's way into the sump. Would it be preferable to drain the sump and add back into the oil tank or leave it as is?
Johnny4428
July 31, 2025, 10:43:14 AM »
Good practice to drain sump after that length of time. I would reuse oil but I would pour through a strainer.
SeanFD
SOHC Expert
"Still running against the wind"
July 31, 2025, 11:29:32 AM »
As above, but when you have the valve covers off, pour +/- 500ml of oil down from the top - divided across the 4 cylinders of course.
You didn't mention it, but I imagine you checked, cleaned and set the points and timing.
Yuppie_88 (Luke)
Newbie
September 01, 2025, 07:59:44 PM »
Just a quick update, thank you again for everyone's advice.
It runs and rides, I took a slow ride out on Sunday to Cannon Hall Farm near Barnsley for an ice cream! Here's a link to quick video of the first start
https://youtube.com/shorts/h7t6eVguyjg?si=Y6qPpfkztvx-6jsJ
Last Edit: September 01, 2025, 08:12:30 PM by Yuppie_88 (Luke)
Johnny4428
September 01, 2025, 09:18:43 PM »
Sounding good there Luke!👍
Laverda Dave
Health is wealth
September 01, 2025, 10:59:56 PM »
Well done👍. It sounds good on the pipe.
neat street
SOHC Expert
Reply #10 on:
September 02, 2025, 07:59:45 AM »
Nice, well done.
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
CB750
