Author Topic: CB750 f2 centre stand  (Read 9688 times)
Offline simongi
« on: December 03, 2010, 11:08:13 AM »
Hi . I am having trouble getting any info on getting the correct centre stand for my 78 F2. Does anyone have any good info/part no's or even better, actually have one stuffed in the back of the garage...?? cheers
Re: CB750 f2 centre stand
« Reply #1 on: December 03, 2010, 12:16:53 PM »
I have one stuffed in my shed for a 1977 K7 don't know if it will fit and centre pivot pipe needs freeing off and replacing
Offline simongi
« Reply #2 on: December 03, 2010, 04:11:51 PM »
How much do you want for it. Send me a text (or call) if you want on 07899 757421 Cheers.
« Reply #3 on: December 03, 2010, 04:45:37 PM »
goggle motogrid look up the bike and part number on the LH side of the menu then cut and paste the part number into the RH  side and it will tell you what other models of Honda, if any, that part fits.
I could do it for you but then you dont learn
« Reply #4 on: December 03, 2010, 05:49:59 PM »
The part no is different one has 405 (K7) in it and the other 410  (F2)  Bryan?
If you are interested 5 quid plus post but don't forget that the centre pipe is stuck in. Last one Freed I had to drill out on my K0
Ash
« Last Edit: December 03, 2010, 09:56:53 PM by AshimotoK0 »
Offline simongi
« Reply #5 on: December 04, 2010, 10:03:31 AM »
Hi Ashimoto. Let me know your address and how much for postage and I'll get a cheque in the post for your stand. thanks
« Reply #6 on: December 04, 2010, 10:51:48 AM »
Are you sure it will fit though?  I will PM BryanJ and ask him if he knows- failing that I can make measurements if you wish
Ash
Offline simongi
« Reply #7 on: December 04, 2010, 04:02:08 PM »
Hi Guys. Bryan. Tried Motogrid, but Vin no's don't seem to tie up with any of their numbers (or am I missing something) My Vin is CB750G-100007797) Is this because its US bikes only?  Ash, if it helps the distance between the lugs is 130mm. Thanks. simon.
« Reply #8 on: December 04, 2010, 08:00:19 PM »
I will check it tommorow and possibly send a pic
Ash
« Reply #9 on: December 05, 2010, 12:44:57 PM »
Hi - dug this literally out of my shed.  :D
Picture has dimensions. I can get it tumble blasted at work but would have to slip the guy a couple of quid !!
Ash
Offline simongi
« Reply #10 on: December 05, 2010, 01:53:44 PM »
Hi Ash. That looks like it may work. Let me know your costs via forum or phone, and I'll get a cheque off. (paypal is also an option). Don't worry about cleaning it up, I'm having my frame blasted and powder coated so the stand can be done at the same time. Thanks, Simon
« Reply #11 on: December 07, 2010, 04:37:23 AM »
I suspect the difference will be either stop where stand hits a bracket or exhaust and/or the bit you put your foot on as the K had 4 into 4 whilst the F was 4 into 1
Offline F2 Paul 876
« Reply #12 on: December 11, 2010, 12:23:23 AM »
This is a F2 main stand.
Paul
Passed Bikes
CB 250 G5
CB 550 K3
CX 500 B2
VT 500 E X2
Still got
CB750 F2   2 off  1 Rebuilding  1 Waiting Rebuild
« Reply #13 on: December 11, 2010, 08:30:15 AM »
Looks pretty similar to me.
Sorry for delay. it weighs between 3.5 and 4 Kg, packed and this is the best I can come up with postage wise.
Best rgds
Ash
Home > Delivery > Business delivery options - UK > Standard Parcels >
Standard Parcels
Overview
Details
Prices
FAQs
How to buy
See the table below for prices of our low cost Standard Parcels service, including packages of various different weights.
Maximum weight   Price
2kg
Offline simongi
« Reply #14 on: December 13, 2010, 09:05:44 AM »
Hi Ash. If you let me know your  address, I'll get a cheque off to you . Thanks. Simon
