SOHC.co.uk Forums > CB500/550
rectifier help please
neat street:
thank you both, as it is diodes and no `bare` electricle parts, could it be placed in an ultrasonic bath to clean, then placed in a bag of rice to dry completly, and laquered (all after test to make sure its all working?
thank you again.
deltarider:
It doesn't require any cleaning. You can test its diodes, but if it does what it is supposed to do, why bother?
neat street:
--- Quote from: deltarider on August 16, 2025, 08:18:11 AM ---It doesn't require any cleaning. You can test its diodes, but if it does what it is supposed to do, why bother?
--- End quote ---
It has the `Green` copper contamination, like rust on steel, I think it should either be nuetralised, or cleaned? my option would be to clean it all off so it does not `creep` over time and as Dave advised, laquer to protect afterwards? just my thoughts as I am going through all the electrics now and changing parts like bullit and terminal block connectors while trying to sort out other electricle `add ons` that should not be there :-) thank you for your comment.
Bryanj:
Carefull with laquer, it does get hot
neat street:
Thanks Brian, not sure if it works yet, has alot of the green corosion which is afecting the terminals, think I will try the sonic clean first and see how I go.
Navigation
[0] Message Index
[*] Previous page
Go to full version
