Author Topic: Hi, newbie from nr Cambridge with my seized '77 400-4 F1  (Read 16575 times)
Offline Seabeowner
Re: Hi, newbie from nr Cambridge with my seized '77 400-4 F1
« Reply #15 on: August 26, 2025, 06:56:26 PM »
Quite a lot of 400/4 owners fit this camchain, its often available at a good price.
400 cam chain Kawasaki Part No: 92057-1011
That's the primary chain Ted. Oddjob (when he's well again) sells a HD cam chain for the 400 and Nurse Julie sells one but needs joining.
1973  CB500K1  Candy Ruby Red
1975  CB550F1   Shiny Orange
« Reply #16 on: August 26, 2025, 08:24:17 PM »
Well spotted, you are correct, hope it's not a sign of Alkasaltzer creeping into my brain.👎
I remember the tank track test now.
« Last Edit: August 26, 2025, 08:27:48 PM by McCabe-Thiele (Ted) »
« Reply #17 on: August 26, 2025, 09:23:21 PM »
If it is that solid you may want to buy ebay item 205681628665 may need boring but will clean where yours may well not clean at 1.0mm
« Reply #18 on: August 26, 2025, 09:50:15 PM »
Whilst the engine is apart I would really, really replace the cush drive rubbers in the clutch basket. These are notorious for drying out, shrinking and cracking causing really bad backlash. Max who was a member on here used to make a full kit to replace them. I'm not sure if he still makes them but here's a link to the eBay seller who is advertising them, it could be Max but I'm not sure.
https://www.ebay.co.uk/itm/126575568549?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=CDD5i3SoTJG&sssrc=4429486&ssuid=5XpGce3OSuS&stype=1&var=&widget_ver=artemis&media=MORE
« Reply #19 on: August 27, 2025, 07:58:23 AM »
If you want Max's email address PM me. Ted
Offline FWM400four
« Reply #20 on: August 28, 2025, 11:33:44 AM »
Thanks guys for your responses, got the block/pistons on ebay last night, so have a back up if mine are completely knackered.
