SOHC.co.uk Forums > CB500/550
brake bleed screw size?
neat street:
From what I can see, its standard??? thank you for your replies, guess someone has messed around with it at some time in its life :)
florence:
the best option for repair I have seen is a stainless steel banjo bolt with bleed nipple in the top. (You leave the old broken nipple in place) I have this arrangement on mine and it seems to make bleeding easier. It's been there for 30 years through rain, shine and salt and still works perfectly.
neat street:
problem kinda solved... Filed the top of the bleed screw hole and yes, someone had put in a helicoil and also damaged the hole for the bleed nipple to work, solution throw it away and buy a replacement... thank you all for your help
Bryanj:
Look at mmatti on amazon, you get complete thing with pads and mounting bracket for what i think is a reasonable price
neat street:
Thanks Brian, yes thats a bargain :-)
Navigation
[0] Message Index
[*] Previous page
Go to full version
