Author Topic: Strange spark plug test result  (Read 718 times)
Offline Athame57
    • SeaWitch Artist
« on: October 04, 2025, 12:06:09 PM »
I'm not firing on my CB400Fs #2 piston. A look at the plug showed a fairy sooty result that was dry, the plug is new. I did the crude test of placing the plug on the cooling fins and hitting the go button to check for a spark. There was a spark but it came off the top of the electriod, not within the gap itself. Any ideas?
I brake for animals!
1978 CB400F2 called Elen.
Offline exvalvesetdabbler
Re: Strange spark plug test result
« Reply #1 on: October 04, 2025, 01:03:41 PM »
Carbon is conductive so the whole plug is now an electrode.  Need to clean it or swap for a spare and retry.
Easiest way to clean a sooty plug is to  heat the end up with a blow lamp to red heat and burn off the soot. Does less damage than a steel wire brush.
Any diesel residues still in the fuel system ?
Regards
Dave
Offline Athame57
    • SeaWitch Artist
« Reply #2 on: October 04, 2025, 01:59:49 PM »
Spark a little better I think but piston didn't fire. This is the carb that the garage put new seals in, maybe I need to clean it again, but why would one carb be more affected than the others? Could it have been because this was the cyclinder that needed reboring more than the others? ( I just had a rebore courtesy Bran)
« Reply #3 on: October 04, 2025, 02:28:41 PM »
Cant see it being anything to do with the rebore.
If the leads are long enough try swapping the two cylinders to eliminate a HT coil lead issue.
Offline Athame57
    • SeaWitch Artist
« Reply #4 on: October 04, 2025, 03:25:21 PM »
Alas, it didn't work either.  :( Maybe I'm going to have to face the hell of putting carbs back in  ::) but not today anymore.
« Reply #5 on: October 04, 2025, 03:36:10 PM »
When the rebore was done, were the valves checked and also clearances set properly upon re assembly.?
To soot up plugs it's either getting way too much fuel or burning something else to create the soot. If it's not firing it would be blowing out fuel from the exhaust, ie smell of petrol.
All choke flaps opening properly?
Float heights correct?
Compression on each cylinder?
Does the no.2 header pipe feel cooler than the others after a short fire up?
Just as a side note, your spark may look to  be a bit weaker when cranking on the starter because the battery voltage drops, pull the lead of 1 or 4 and test the same suspect plug on the other  coil.
 Other than that I would be looking to see if fuel is getting  past the o ring on the main jet.
Regards
Dave
« Reply #6 on: October 04, 2025, 04:13:47 PM »
Swap the #2 plug with #3 .... then run it to assess.
Both of those plugs run on the same coil .... if the problem remains where it started ... likely the carb is next suspect. That's assuming you already swapped  2&3 plug leads with nil effect ?
Offline Athame57
    • SeaWitch Artist
« Reply #7 on: October 04, 2025, 06:23:32 PM »
I had a different garage do those at the same time as I had them fit the header pipe properly. Bike was great for a day and now this. I expect I'll be heaving the carbs out.  ::)
« Reply #8 on: October 04, 2025, 08:30:29 PM »
That diagram is all wrong.
As you sit astride the bike Cylinder 1 is on the far outer left, then its cylinders ,2,3,4.
Offline Ken4004
  • Semi retired hiding from wife in shed
  • Triumph Tiger sport 2013. Honda CB 400 4
« Reply #9 on: October 04, 2025, 09:01:04 PM »
I had the same issue last week one cylinder not firing turned out to be the carb putting too much fuel into the piston so carbs out and changes the float fuel valve that wasn’t closing properly and flooding the carb.
After replacing valve and reassembly started up with no issues.
Offline Athame57
    • SeaWitch Artist
« Reply #10 on: October 04, 2025, 11:17:52 PM »
Right, I'll delete before it does anymore harm!
« Reply #11 on: October 05, 2025, 12:10:16 AM »
I only had the block so no idea about valves
