General > New Member Introductions
Newbie from West Sussex
<< < (5/5)
Bryanj:
If you remove the starter motor in the hole it fits into you will see a toothed gear, you need to see if that will spin both ways easily, if so the sprague clutch is gone
Otis:
--- Quote from: Orcade-Ian on November 19, 2025, 09:14:40 AM ---Welcome Graham from a slightly chilly Orkney,
I too have a 350 Four but not as nice as yours.
(Attachment Link)
  Are you sure it's the starter clutch - have you had the starter motor out - the easy bit?  As far as reluctance to start when cold goes - did the PO strip the carbs?  Yes, they are a bit of a bugger to remove/refit but worth doing right once.  Nearly everyone on this forum will tell you not to replace the brassware but use originals thoroughly cleaned.  I also had a DOHC 750 - an FA.
Ian
--- End quote ---
I think you underestimate how lovely your 350 is; great colour. I think I would sacrifice a little bit of shine for a working starter!!
Yes, I had the starter out and swapped it for another to try but it was exactly the same. While it was out I was able to move the clutch and with minimal effort it seemed to act as expected ie. moves in one direction only but perhaps under more torque it slips. I have seen a video where a chap overhauled the clutch from the side and beneath but as you say it is a real fiddly job and I could see much grief coming. My first step will be to drain the oil and remove the sump to see if there are any lurking springs or rollers. Interestingly and dare I say slightly suspiciously I noted from the invoice history that there had been a new sump gasket fitted shortly before I purchased it so it could well be that the PO had already done the same check?
With the help of a friend we fully removed and reset the carburettors but the worst thing we found was that the electronic ignition was way out. After this was corrected the performance of the bike was stunning and runs beautifully when I do get it started.
What a coincidence that you also had a 750F.
Thanks for your guidance Ian and just for your information John from Orkney knows all the buggers I know. What an amazingly small world.
Graham
Rayzerman:
Welcome, Graham.  I'd love one of those Z900's as well, unfortunately many do and I can't find a bargain, lol.
Athame57:
Hello Graham
Welcome here, nice bike pics!  ;D
Rayzerman:
I would first run that engine a bit with fresh oil and hopefully it's just gummed up a bit..... otherwise, a big job.  Good news if the starter gear turns only one direction.
From my experience so far, it's a finicky job to get the ignition set up properly.  Do remove the advancer and give it a good clean.  Many have advised getting original point sets, and I did have some crappy aftermarket ones.  Well worth spending the time getting it right.  As for the carbs, same deal, float levels need to be right and bench sync'd..... then onto the bike and check ignition timing... vacuum sync the carbs.  It can be a little cold-blooded to start, but once you get it tweaked in, should be good.
I'd love one of those Z900's.
Navigation
[0] Message Index
[*] Previous page
Go to full version
