Project Board
Keiths 400/4
4
5
6
7
8
Topic: Keiths 400/4 (Read 56866 times)
taysidedragon
Re: Keiths 400/4
Reply #60 on:
May 05, 2026, 04:12:34 PM »
Check all earth connections.
Coppertop1234
SOHC Expert
As long as the wife is happy
Re: Keiths 400/4
Reply #61 on:
May 06, 2026, 05:53:14 PM »
Checked wires and cleaned all joints and earths - all disconnected and cleaned replaced back in order
Headlight now not an issue can turn lights on and off with engine running ok
Fusebox was a pain with fuses just collapsing, they were getting on a bit and silver ends were falling off when i touched them
(seem ok at moment will get a pack of new fuses to make sure)
Flasher unit was an led flasher unit ,took it off and it just packed in so i have ordered a new one
end of play for today till new units come tomorrow.
At the moment I am thinking the problem was related to the flasher unit, rather than wiring, but we will see tomorrow
Hope it was
I Love Tinkering with Old Classics
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1962 Triumph 650 Bonneville
1972 Norton Commando
1978 Honda CB400/4
1976 CB750F1
1976 Suzuki GT750 Kettle
1978 Honda CB 750 F1
Married Life No Bikes for a while then
1975 CB Honda 400/4 Restoration
1976 Kawasaki Z650 Restoration
2002 Suzuki GSX1400
1976 Honda cb750F1 Restoration
1978 Honda cb750 F1 Restoration
1977 CB 250 Dream Restoration
1977 CB400/4 - The last one - Restoration
Re: Keiths 400/4
Reply #62 on:
May 06, 2026, 08:17:38 PM »
Correct glass fuses have been getting hardercand harder to find in correct size, if you go to US site and look up Hondaman he mahes and sells a replacement that takes the blade type fuses
Coppertop1234
SOHC Expert
Re: Keiths 400/4
Reply #63 on:
May 07, 2026, 06:42:06 PM »
well one step forward 3 back
flasher unit fitted indicators all flashing as they should.
not started bike yet.
idiot console went blank no power
tank off checked harness connections all look fine
Headlight out all connections look fine no wires out or loose
checked fuses all ok
checked connections all ok
still no power to ignition
tried fuse between fuses yup powers up ignition and cranks over
not tried to start it at this point but think she would fire up
checked fuse box out all wires good and connections ok
next thing i can think of is ignition connections, but these power with fuse bypass ok so probably not
stumped at moment maybe its the diode at side of fuses? Rectifier?
Any comments appreciated
Last Edit: May 07, 2026, 07:06:59 PM by Coppertop1234
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
Re: Keiths 400/4
Reply #64 on:
May 07, 2026, 07:37:32 PM »
Not sure what you mean by fuse between fuses, the diode is only for thestarter interlock(neutral light on OR clutch lever pulled in)
It is not unusual for the block connector to come loose on ignition switch and/or the contacts in the switch part to fail
Coppertop1234
SOHC Expert
Re: Keiths 400/4
Reply #65 on:
May 07, 2026, 07:48:36 PM »
If you place a fuse inbetween the space where a fuse should not go it powers ignition as if a key is in bike
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
Re: Keiths 400/4
Reply #66 on:
May 07, 2026, 08:54:09 PM »
Then something is wired wrong as only 3 fuses do anything
1 main
2 tail and instruments
3 head
The other 2 are spares
Oddjob
Re: Keiths 400/4
Reply #67 on:
May 07, 2026, 10:35:19 PM »
It’s the old dodge/thieves trick to start a bike with that sort of fuse box Bryan. You fit a fuse between the main fuse and the next fuse inline. That acts as a direct short to power both circuits. However it should only work if the headlight switch is also moved to the on position. For some reason Honda powered the lighting circuit so it stayed on all the time. Most likely to run parking lights. It didn’t take long for the thieves to spot the fault. Everything lights up and the engine will start. Honda even provided the spare fuse to jump it with.
It was the main reason when I fitted my 500 with a 550f harness that I kept the old ignition switch under the tank. I still used the 550 switch between the clocks but until the 500 switch is in park, so I can remove the key, the rest of the systems stay completely dead. I wired it so the main feed wire to the fuse box runs through the 500 ignition switch and then back to the fuse box.
Last Edit: May 08, 2026, 03:49:05 AM by Oddjob
Re: Keiths 400/4
Reply #68 on:
May 07, 2026, 11:59:22 PM »
Never heard of that one Ken, perhaps i worked in a less theivefull area, from that info suggests the ignition switch contacts are bad so try unplugging the switch connector block and jumping red to black, if it all lights up then the contacts are duff so new switch or Emgo contact unit but i would fit a relay
Oddjob
Re: Keiths 400/4
Reply #69 on:
May 08, 2026, 03:55:56 AM »
I’d agree with Bryan, most likely a poor contact set in the switch. They can be disassembled though and cleaned up, done it a few times, just be careful you don’t snap the retaining lugs.
As Bryan also suggests jump the red and black wires together first. If it all lights up it’s the switch if not it’s something else.
Coppertop1234
SOHC Expert
Re: Keiths 400/4
Reply #70 on:
May 08, 2026, 10:51:29 AM »
Well later today when I land home we should see which parts iffy. Son has brought me all electrical parts to try 1 at a time from a bike we have not started on yet.
Unless I am unlucky and it has similar issues.
I will update as we progress further
Thanks for imput always helpful to have differing opinions and possible sources to investigate.
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
Coppertop1234
SOHC Expert
Re: Keiths 400/4
Reply #71 on:
May 08, 2026, 02:04:15 PM »
Stage 1 replaced easy swaps
Fuse box
rectifier
Dioder + Regulator
Flasher unit
No difference all original parts replaced and on to the ignition for stage 2
Looks like I found culprit loose wire on coupling block for ignition.
Last Edit: May 08, 2026, 05:25:55 PM by Coppertop1234
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
Coppertop1234
SOHC Expert
Re: Keiths 400/4
Reply #72 on:
May 08, 2026, 05:03:22 PM »
First proper test ride out to local car spares about a mile away for some fuses
Told wife I would be back in 5 or an hour all depends.
Little bike rode very nice and didn't fault on anything.
So hopefully problems solved.
Got some spare 15 amps but no 7s so I will order some on line to sort it.
may go to Chesterfield on Sunday to a classic meet and give her a bit more of a run.
Last Edit: May 08, 2026, 05:27:47 PM by Coppertop1234
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
Coppertop1234
SOHC Expert
Re: Keiths 400/4
Reply #73 on:
May 21, 2026, 04:19:17 PM »
Same fault returned when Indicating engine falters and stamers to flash speed.
Checked wiring and nothing visible found a few badly taped up wiring joints i was not happy with,so I can only presume its a earth leak somewhere in the bindings of the harness.
Previous owner wiring repairs were twist and tape not a permanent fix so could be anywhere,
New harness on its way so.hopefully that will sort it.
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
Coppertop1234
SOHC Expert
Re: Keiths 400/4
Reply #74 on:
May 25, 2026, 07:27:15 PM »
New harness fitted all working as it should
Polish tinker and take for a spin.
Son took it home tonight to give it a run on motorway
All rode fine slight issue on back lanes,
a pheasant decided it also liked the bike at 60 mph.
Feathers all over broken sparkplug and suppressor
But alls alright pheasant still flew off and bits to now sort out.
I was hoping it would have taken longer but jan to may passed 5 on
Went out on sons 750f1 while we were test riding and I am tempted,but as I said this is my last 1 I will just supervise and polish the 400
Last Edit: May 25, 2026, 08:39:24 PM by Coppertop1234
1970 Mobylette 50cc
1972 Honda Cb175
1974 Yamaha Rd250
1978 Honda CB400/4
1976 CB750F1
2002 Suzuki GSX1400
4
5
6
7
8
Project Board
Keiths 400/4
