Author Topic: What Special Tools Will I Need?  (Read 12022 times)
Offline Neilw
Re: What Special Tools Will I Need?
« Reply #15 on: February 01, 2026, 09:21:38 PM »
Fuse box go to US site and look up Hondaman(mark paris) he makes a blade type fusebox that is a direct replacement.
Fuel pipe.i have some genuine Honda left £10 per meter plus postage pro rata for shorter.
RH switch be carefull with part number as i noticed some sellers dont quote the right end number which changes with country, make sure it has the lights on/off on it as the US one does not
Thank you, i've found Hondamans site and will contact him.
Offline Nashfly
« Reply #16 on: February 03, 2026, 08:09:07 PM »
Probably worth investing in a carb sync tool - I use the Morgan Carbtune (others available)
