Author Topic: On copper exhaust gaskets.  (Read 5219 times)
Offline Athame57
« on: March 21, 2026, 09:16:04 PM »
Can anyone tell me if copper exhaust gaskets are an improvement over the originals?
1978 CB400F2 named Elen.
Re: On copper exhaust gaskets.
« Reply #1 on: March 22, 2026, 11:18:17 AM »
Can you still buy the originals George considering they contained asbestos?
I've always used cooper gaskets although some appear to fit better than others. I normally tap mine home using a suitable sized socket in order not to distort them. When I tighten the header pipes I do it in stages across all four pipes to make sure they are all seated correctly.
Never had a cooper gasket blow at the joint so maybe not better than but equal to the originals in my opinion 👍.
« Reply #2 on: March 22, 2026, 01:06:51 PM »
They aint solid copper but have some sort of compressible filler in them, and that was original by the way
« Reply #3 on: March 22, 2026, 01:22:17 PM »
Thanks for the clarification Bryan. I remember taking some out back in the 80’s on my 400/4 at the time they were made of a white woven material (asbestos?) and were spiral bound with very thin wire. I immediately thought they looked very dodgy and they left fibres in the port.
Offline kevski
« Reply #4 on: March 22, 2026, 03:09:05 PM »
I’ve noticed as of late a lot of these copper rings are only copper plated steel and aren’t really up to the job, so now I have gone to the aluminium and fibre type, put a magnet to the copper ones if it picks them up they are cheap Chinese fake rings.
Offline Athame57
« Reply #5 on: March 22, 2026, 03:11:36 PM »
Like the ones I have then.  ;) I mangled the first ones I fitted but succeeded 2nd time, I had ridden a few thousand miles after I bought the bike none the wiser. Okay, next time the pipes come off, copper ones go in! Thanks everyone.  8)
Offline Athame57
« Reply #6 on: March 22, 2026, 03:13:09 PM »
I have a magnet, will check, I won't be buying the cheapest!
