Author Topic: 1976 CB550F new member  (Read 431 times)
Offline Orcade-Ian
    • Older Vehicle Web
Re: 1976 CB550F new member
« Reply #15 on: April 03, 2026, 08:26:40 AM »
James,
I got a lovely new old stock brake pedal from Ken (Oddjob) and as he says, he has one left!  What's the famous come-on in almost every advert? 'Hurry, while stocks last'. If funds won't stretch that far, I have the one I replaced it with.  PM me if needed.  I should be meeting up with my Hull mate in the Highlands soon (assuming fuel available and no lockdowns - grrrrr!!!) and he will be going back home to Hull later - easy courier if needed.  I don't have a kickstart but I do have a few US spec indicator bodies and lenses - all used, some good.
Ian
Offline Towsejames
« Reply #16 on: April 03, 2026, 12:48:27 PM »
I will send you a message once I have investigated closer. I have ordered a cb550F kick start lever which looks to sit out longer. I will see if this changes anything first
Online 3scs
« Reply #17 on: April 03, 2026, 01:07:39 PM »
I might have what you need including the return spring which is different to the k one on e bay strangely enough I bout a k3 a few years back which had a lot of parts from the f on it the brake cross shaft is also different how desperate are you asi need to swap mine which means removing the swing arm it’s on my list of jobs to do and I’m not far from you also
Offline Towsejames
« Reply #18 on: April 03, 2026, 03:20:21 PM »
Online 3scs
« Reply #19 on: April 03, 2026, 03:48:31 PM »
Hi mate measure this distance and this is the correct pedal and return spring I believe
Offline Towsejames
« Reply #20 on: April 03, 2026, 11:19:51 PM »
I get approx 120mm
Online 3scs
« Reply #21 on: April 04, 2026, 11:54:45 AM »
Yes that looks right I’ve got the brake pedal and spring here ready if you want them
