Anorak's Corner
(Moderator:
AshimotoK0
Which fire extinguisher
Topic: Which fire extinguisher (Read 12621 times)
DomP
April 16, 2026, 10:47:51 PM »
All this tinkering with carbs and fuel has got me thinking I should invest in a fire extinguisher, ive done some research into them but wondered what you all recommend? Powder seems the go to choice but it would appear its very corrosive, maybe not an issue when the other option is a pile of melted parts, foam is soon to be banned which leaves CO²
1975 XS650B
1976 CB550F1 current project
2012 Triumph Daytona 675
TrickyMicky
Re: Which fire extinguisher
April 16, 2026, 11:09:35 PM »
It's only certain types of foam extinguisher which are to be phased out. CO2 gas models are very good, but can still leave hot spots as the gas clears. Just remember that fire needs 3 ingredients:- fuel, air, and heat. It only needs one removal of these to kill a fire.
Murf
SOHC Expert
April 16, 2026, 11:42:25 PM »
Dry powder is the most popular for home type use these days and is readily available. It is good for oil and fuel fires, electrical fires and general house fires. Downside is it makes a lot of mess and a lot of cleaning up. But like you say the alternative to not using it is a lot worse. Dry powder extinguishes should be changed after a number of years as the powder can start to become packed down, particularly with vibration when the extinguisher is carried in a vehicle.
Good all round general fire extinguisher.
Foam is also good for oil and fuel fires, should not be used on electrical fires and not a good choice for general house type fires. It also makes a horrible mess and is more for industrial type situations.
CO2 is good for electric fires, it will put out oil and fuel if you are really quick and get the fire right at the start but there is risk of reignition as the CO2 disperses. not much use on oil fires once they start to take hold because of the reignition factor. Not sure how CO2 extinguishers fit in with environmental concerns nowadays.
We carried water, foam and CO2 extinguishers on the RN ships, powder wasn’t a big thing back then.
DomP
April 17, 2026, 11:22:02 AM »
Ive ordered a 2kg powder for my workshop (woodwork rather than bikes) but I think ill get co2 and powder for my bike garage, co2 of fuel fires when working on cards and powder for worse situations
1975 XS650B
Spitfire
April 17, 2026, 11:48:07 AM »
After nearly 40 years working on oil refineries I've used them all on too many occasions, but in the house and garage I have CO2.
Johnny4428
April 17, 2026, 01:09:47 PM »
Sometimes we like to be different, sometimes we take what can be salvaged!!🤫
Spitfire
April 17, 2026, 01:37:24 PM »
Now thats a blast from the past, I'll have to tell Greta.
April 17, 2026, 01:54:22 PM »
Doing a firefighting course in the Merchant Navy in 72 i was taught you can put a fuel fire out with water you have to bounce it of a steel bulkhead to turn it into a "fog"
exvalvesetdabbler
April 17, 2026, 03:23:49 PM »
Engine room fires on small ships is no fun. Was on a small survey ship once when diesel was being sprayed over hot engines, the crew managed to cool the engines down quickly using the deck hose and then ventilate the space. Came very close to pulling the big red handle in the wheelhouse. I was initially tasked with going up on the monkey island to close the engine room vents just in case it went up. Whole place stunk of diesel for weeks after that despite a gallon of jizer to wash down the engine room
Dave
Johnny4428
April 18, 2026, 09:40:54 AM »
Yes Greta! Well rightly or wrongly? the tree hugging Greta’s of the world decided that Halon was bad for the Ozone layer. Although all contained in pressurised cylinders and unlikely to be detrimental to the environment. I guess maybe the disposal of said Halon during periodic cylinder inspection and pressure testing. Something like 10years, can’t remember. But a massive cost to the industry changing out all fixed ff systems and replacing with co2 as well as all site wide individual extinguishers. Just remember vaguely about a Paris agreement.
Alimacdee2
SOHC Associate
Reply #10 on:
April 22, 2026, 10:51:42 PM »
I recently went for a 6kg dry powder extinguisher, covers a wide range of fire risk, and 20sec of discharge, also useful if some low life’s here decide to torch my workshop, this is the world I live in theses days, 29.99 for some peace of mind!
6kg Dry Powder (ABC) – 21A 144B C
Last Edit: April 22, 2026, 11:25:01 PM by Alimacdee2
1970 HONDA CB750
2002 Ducati Monster 750ie
1971 Triumph Trophy T100C
Anorak's Corner
(Moderator:
AshimotoK0
