SOHC.co.uk Forums > CB350/400
Front brake squealing
Ken4004:
--- Quote from: exvalvesetdabbler on May 02, 2026, 05:52:23 PM ---For something to compare with mine start to squeal after about 600 miles after deglazing. But I do quite a bit of around town riding so you tend to be on the brakes gently quite a bit.
When it was mot tested the numbers were always good even when squeaking.
Regards
Dave
--- End quote ---
I have not had an issue with the braking force it stops quite well for an old bike,
exvalvesetdabbler:
--- Quote from: Bryanj on May 02, 2026, 01:23:38 PM ---If its squealing pushing it around the caliper/pivot is not moving free enough or slight hydraulic pressure is staying on, lines/master
--- End quote ---
Like this
https://youtube.com/shorts/IIXshEcfX28?si=oC4CLmS_usQEw9R_
Regards
Dave
Ken4004:
Ok thanks Dave
Ken4004:
--- Quote from: exvalvesetdabbler on May 02, 2026, 08:36:25 PM ---
--- End quote ---
Like this
Regards
Hi Dave thanks for the video, just checked the brake arm as you suggested and it’s very free so behaving like yours , just going to scuff up the pads again while it’s off.
Dave
--- End quote ---
Ken4004:
Slight glazing after bedding in again but not as bad as it was probably going to have to live with cleaning the pads every now and then simple job so not the end of the world
Navigation
[0] Message Index
[*] Previous page
Go to full version
