Try our re-instated info resource - "Aladdin's Cave" (Main menu)- sorry it's taken so long to fix
Everything set up again today so just to recap.Can anyone recommend a new set of coils for my 400 4 that are decent , original coils are ok but leads are moulded in so cannot be changed so ideally I would like some coils that I can change the leads on when they get ropy.
I noticed yesterday that no 2 exhaust pipe warmed up a little slower than the test although it seemed to start OK so I believe the cable / plug on no 2 is occasionally breaking down.The leads on all plugs are a bit short like they have been shorted a number of times so time for new hardware .
Quote from: Ken4004 on May 04, 2026, 06:22:21 AMI noticed yesterday that no 2 exhaust pipe warmed up a little slower than the test although it seemed to start OK so I believe the cable / plug on no 2 is occasionally breaking down.The leads on all plugs are a bit short like they have been shorted a number of times so time for new hardware .That rings alarm bells for a poor running cylinder. Given that your other investigations have not given anything confirmed as probable cause, that partially missing cylinder needs investigating for both ignition and idle circuit fuel supply.Off to Kefalonia in Greece for three weeks , going around the whole Island staying one or two nights in several places so should see the whole island,I was looking at endoscopes a couple of months ago and thought it might be useful bit of kit and it appears that I was right , I did a very detailed and meticulous clean of the carbs when I had them off the bike but as I said before I am not ruling anything out.I was going to change the coils anyway in the future because of the dodgy looking leads so this is a good a time as any to get it done and cross another possibility off the list.Thanks for the advice regards KenIf you have a borescope it would be worthwhile looking in there to see if there's anything untoward. The cheap type for phone, with front & side facing camera are really good value to get decent inspection. Hope you have a good holiday, anywhere interesting ?
Quote from: Bryanj on May 02, 2026, 11:19:51 PMI think you have an electromechanical gremlin that stoped the engine and starter didnt workStill in gear and clutch lever not pulled all the way in. We have probably all done it much to the annoyance of cars behind us.Dave
Hopefully you'll get to the bottom of it with the coil rebuild, then verify its firing properly on all 4 cylinder.Running on three will cause it to be a heat risk, as you've found. They've only about 24 ft/lb of torque @ 7500rpm when healthy, so starting with approx 18 lb and running below peak torque will likely bring about 15 lb at a, licked finger in the wind, estimate. Trying to pull uphill like that will severely compromise its output, ultimately to cause lean running through that set of circumstances. Essentially, the crank rpm can not "follow" throttle opening as there's insufficient torque to accelerate the bike and rider. That causes you to open the throttle further, which drops the vacuum affecting jets, to then run permanently lean (if the crank rpm never catches the throttle slide position) up gradient being the biggest risk, as it can never catch up. "Lean" running, in and of itself doesn't necessarily increase heat as a cause. What happens as the combustion chamber reaches its ability to burn fuel as it approaches the 14.7:1 ideal (stoichiometric) the propagation of flame front outward from the spark plug begins to break down such that the burn phase doesn't spread out to far reaches of tbe periphery of piston/chamber. This results in unburnt "gas" mixture in a ring around that periphery, which then explodes rather than burns as piston comes to tdc. Its this uncontrolled event that gives a shock wave that breaks the boundary layer protecting the piston crown from exposure to high heat and subsequently raises the overall temperature if left unchecked. When more extreme, we can hear this as "pinking" but it starts in virtually inaudible levels before we become aware of it in more severe form (we're isolated from source & with helmet sound insulation too) but it happens and significantly shifts the temperature accumulation, that also being relative to the ambient air trying to cool tbe motor and it's capacity if moving more slowly. Detonation is the process, as there's loss of control thats fundamental to how the fuel air mix is supposed to combust, rather than explode. Essentially it has the effect of advancing the timing to detriment of the engine's desirable running condition. There's another phase going on from this as too much of the above will likely bring pre-ignition, which is usually catastrophic, and in short time frame too this will definitely put a hole in tbe piston for you!Seems like you've got away with it in recent description, but quite close to serious damage though.
