Hi everyone just a quick update.
I have rebuilt the ignition coils as per the mod by Ash and fitted the coils back on the bike and rechecked the resistance , around 24.5 k on each of the coils so all looks good.
During my investigation released that the incorrect spark plugs were fitted so I had resistor plugs and resistor caps fitted so have changed the plugs to non resistor version so should get a stronger spark.
I have checked all the cylinders with an Edoscope looking through the spark plugs and holes and all look good except for cylinder two which had deposits of carbon on the piston head because cylinder two was not firing all the time.
Just taken it out for a run and it is pulling better, the flat spot seems to have gone , there is not a strong smell of unburned fuel and doesn’t appear to be getting as hot but the jury is still out , I might try and borrow a digital thermometer to check the engine temp after a longish ride.
Was going to take it for a longer ride but the heavens have just opened so looks like heavy rain for the rest of the day , when the engine cools down I’ll check the colour of the plugs and then decide to try and tinker with the air screws again.
Regards Ken
