Author Topic: Crankcase oil leak  (Read 3626 times)
Offline rosco
Crankcase oil leak
« on: May 24, 2026, 10:13:54 AM »
After finding an oil leak from around the front mount I removed the engine and the lower crankcase and sent it for repair to an old mate of mine at Badfoot Customs
Now returned I thought you may be interested in a few pictures showing the process of how he did it
Offline rosco
Re: Crankcase oil leak
« Reply #1 on: May 24, 2026, 10:26:59 AM »
Sorrywas having trouble downloading photos
Offline rosco
« Reply #2 on: May 24, 2026, 10:49:19 AM »
Another photo showing cracks in oil gallery Which has also been repaired
« Reply #3 on: May 24, 2026, 12:10:10 PM »
Impressive workmanship, was the damage caused by an overlong engine mounting bolt by a PO?
« Reply #4 on: May 24, 2026, 12:39:37 PM »
Usually caused when case guards are removed and the longer bolts put back it
Offline rosco
« Reply #5 on: May 24, 2026, 09:47:11 PM »
Both spot on Guards removed Which makes the bolt longer and punches the oil gallery This was done by the previous owner and during time after an engine rebuild the poor welding eventually gave up and allowed oil to weep through
He has made an absolute cracking job of the repair I could have had it done locally   But I trust my mate and know he will do it right
« Reply #6 on: May 26, 2026, 09:36:51 AM »
Very impressive repair. I had the same issue on mine. I took the crankcase to a guy in SE London called Specialist Welding Services.
Where is your guy located?
« Reply #7 on: May 27, 2026, 07:05:23 AM »
Quite amazed at that repair, not that guys “first rodeo”.
Offline rosco
« Reply #8 on: May 27, 2026, 10:03:05 AM »
Hi Dave  Russell is in Byram near Knottingley  Yorkshire  near the junction of A1 & M62   I sent it by post. around £20 But I knew he would do it right first time so worth the postage  The guy is absolutely brilliant  Check out all his other work of Facebook Under Badfoot Customs
