Author Topic: Carbs got to come off again  (Read 5201 times)
Offline Ken4004
« on: June 17, 2026, 03:17:50 PM »
The old bikes are a present that keeps giving so sorted the issue out with the bike not pulling properly and over heating which now seems to be fixed so please with that but now the bike is harder to start and won’t idle so looks like there is an issue with the pilot jets being partially blocked so got to take the carbs off again and give them a good clean.
I thought if I am going to all this trouble I’ll buy some more quality fuel hose and replace the whole lot, empty the tank and give it a slosh round with fresh fuel (e5) .
Just in case ( I know alot of people don’t like them but I am going to replace the sintered fuel filter with a paper one.
So just as a question what’s the average amount of times you have to remove your carbs over a calendar year ?
Re: Carbs got to come off again
« Reply #1 on: June 17, 2026, 03:30:29 PM »
Normally zero
Just an idea
Put some carb/injector cleaner in the fuel every so often
Help keep the carb internals clean
Redex or similar
Offline exvalvesetdabbler
« Reply #2 on: June 17, 2026, 06:21:03 PM »
About 10 year ago for me, when I got tired of a sticky float and puddles on the floor after it had been stood for a week or more. Float valve was ok, the frame on the float had been bent and was getting stuck once it rested on the bottom.  Substituted another float and no problems since.
I do drain and flush  the carbs out before a winter lay up. Just feed it from a remote reservoir  of white spirit down the fuel pipe.
Regards
Dave
Offline Ken4004
« Reply #3 on: June 17, 2026, 08:10:54 PM »
Regards
Dave
Hi Dave
Do you leave the white spirit in the carbs or are you Just driving out all the fuel with the white spirit then drain it out ?
« Reply #4 on: June 17, 2026, 08:16:05 PM »
Leave it in.  I do put about 3 spots of engine oil per 300 ml.. just drain it out in spring, connect up to the fuel tap, turn it on and it's fires up 3rd kick.
Regards
Dave
Offline Athame57
« Reply #5 on: June 17, 2026, 08:22:30 PM »
So far not in 2026 at all.  :)  That said, 'too often' is all I can say, definitely a bit of bad luck and lack of experience involved  :o and then there are the plenty of times that someone else did it.
« Last Edit: June 17, 2026, 08:24:25 PM by Athame57 »
1978 CB400F2 named Elen.
Offline Ken4004
« Reply #6 on: June 17, 2026, 08:46:48 PM »
Thanks for the feedback guys I’ll try some preventative measures to try and keep my carbs in fine fettle and keep my fingers crossed.
Offline Mikep328
« Reply #7 on: June 18, 2026, 07:08:44 AM »
  2+ years ago, just after acquiring my 400, I pulled the carbs. It idled badly and bogged severely when given full throttle.  I pulled/cleaned/adjusted the carbs, reinstalled them and found the bogging reduced considerably though still present and the idling was still poor.
So I pulled them again and found that one of the idle jets was still clogged.  This time I used a piece of wire and thoroughly cleaned all passages with that/carb cleaner.  Put the carbs back on.  Still didn't idle well.  Took the carbs off again and looked carefully at everything - using magnifier glasses.  I discovered that two of the slow jets had distorted "holes."  It appeared they had been longitudinally crushed and some of the holes were now egg-shaped/smaller than the original holes.  I replaced the two slow jets.  Carbs have been fine ever since - idles perfectly/takes the throttle with no bog at all.  As far as how often they "need" to be pulled," - I owned a 550 and three 750 fours back in the day and never had to pull the carbs on any of them the entire time I owned/rode them.  BUT they were ridden almost every day. One of the worst things for mechanical devices is sitting unused...
FWIW,  my 400F sits for approximately 4 months every year; I put some StaBil fuel stabilizer in the normal (E10) fuel for each layup.  I use Stabil in all our vehicles during storage.  One motorcycle sat for 2 years in storage and started immediately with no problems.  All of our vehicles (cars and bikes) sit for a minimum of 4 months unused, some sit for nearly 8.  Been doing this (fuel stabilizer) for MANY years now and all the vehicles will start after storage as if they had been running yesterday.  We only use "normal" fuel - typically E10; I have never made any attempt to find/use non-ethanol fuel.
« Last Edit: June 18, 2026, 07:24:51 AM by Mikep328 »
Mine:
1976 CB400F
1973 Norton 850 Commando
2015 BMW R9T
2017 BMW R1200RS
2021 Moto Guzzi V7 Special
Wife's:
2015 Ducati Diavel
2019 Honda Africa Twin
2019 Honda NCT750
« Reply #8 on: June 18, 2026, 10:15:44 AM »
I have some  miller oils ethanol protection fuel stabiliser and carry a small 8ml bottle in my jacket pocket and empty that in the tank when filling up.  Never used E10, the cost difference to E5 isn't worth worrying  about given the small amount I used.
Regards
Dave
Offline Ken4004
« Reply #9 on: June 20, 2026, 09:39:18 PM »
Well I stripped down the carbs and have found light brown deposits in all the bowls, some in the form of fine particles and some a little larger.
Not sure what this is , might be rust but there’s no sign of it in the filter, so new hoses and a new paper filter purchased and as Dave suggested once I have flushed out the tank I will add some fuel stabiliser and see how I get on.
Cleaned the bowls with carb cleaner and removed the pilot jets and have them a blast  with cleaner , Also blasted the pilot jets and galleries do will fit them back on the bike in the next couple of days.
Hopefully adding the fuel stabiliser will prevent it coming back but only time will tell.
« Last Edit: June 20, 2026, 09:42:12 PM by Ken4004 »
« Reply #10 on: June 20, 2026, 11:22:37 PM »
Probably fine rust particles from somewhere. Did you reuse old fuel line which could have had a coating inside that's come loose. The fuel stabiliser prevents oxidation of the fuel and is also supposed to prevent it going corrosive once it's absorbed moisture. Oxidation of ethanol eventually makes vinegar(acetic acid).
You can usually tell if the fuel has gone corrosive when the brass ware looks like dull copper where the zinc has been strippe away from the surface. Dezincification of brass is well documented.
Regards
Dave
Offline Ken4004
« Reply #11 on: June 21, 2026, 08:15:55 AM »
Regards
Dave
Hi Dave yes I did use some of the old fuel lines but have now bought all new fuel lines so as you say it must have come from the old fuel lines as I cleaned everything else.
Another lesson learned !
Offline Ken4004
« Reply #12 on: June 21, 2026, 06:32:16 PM »
The carbs are back on and the bike is running and idling well now, starts first kick so  let’s see how long this lasts fingers crossed.
« Last Edit: June 21, 2026, 07:11:54 PM by Ken4004 »
Offline Mikep328
« Reply #13 on: June 21, 2026, 06:48:20 PM »
 "starts first kick so  let’s see how long this lasts fingers crossed."
So next is fixing the electric starter?    ::)
Mine:
1976 CB400F
2015 BMW R9T
2017 BMW R1200RS
Wife's:
2015 Ducati Diavel
2019 Honda NCT750
Offline Ken4004
« Reply #14 on: June 21, 2026, 06:55:52 PM »
Electric starter works fine I was just seeing how many kicks it would take to start
