Try our re-instated info resource - "Aladdin's Cave" (Main menu)- sorry it's taken so long to fix
As you will have found out as you slide it in place the shaft moves into the hub.
There's often a "blank" spline area on the spindle to prevent the brake arm being moved incorrectly to another part of the tooth engagement too.Prevents both wrong assembly position or someone trying to compensate for knackered shoes by moving the arm
Was a common practice to file one spline out of the arm so you could move it round and use up the brakes shoes, brake shoes were expensive!
As you will have found out as you slide it in place the shaft moves into the hub. I had one of those tools that is like a screwdriver except it's a pointed tapered end. I was able to push the tapered point into clamp bolt hole and this pulls the shaft out of the hub as the taper meets the bolt recess part of the shaft.
Quote from: Bryanj on July 04, 2026, 03:09:46 PMWas a common practice to file one spline out of the arm so you could move it round and use up the brakes shoes, brake shoes were expensive!LOL! The last time I had mine changed the mechanic said I was doing it too soon.
