Author Topic: Fork Seals  (Read 8852 times)
Offline Otis
Fork Seals
« on: July 07, 2026, 10:45:57 AM »
On Sunday after a short run of say 5 miles and having met up with some guys it was noticed that my front offside tyre had some moisture streaks on it. Fork seals were mentioned and one chap felt around the lower end and said "yes definitely a weeping fork seal". Another chap said to wipe it all clean and see if it occurs again. Well typically, it hasn't occurred again after circa 60 miles of riding and everything is as clean and dry as a whistle as I write.
My only thought is that on the Sunday I recall hitting a quite depressed manhole cover and felt the forks bottom out; it was quite a jar.. Could it be possible that a significant compression like this could actually force a little oil past the seal or would the consensus be that it is likely that a seal is failing?
Any thoughts/guidance would be appreciated, thank you
Graham
1972 Honda CB350F
1997 Ducati ST2
Re: Fork Seals
« Reply #1 on: July 07, 2026, 12:42:11 PM »
With correct amount inside nothing should come out on max compression
Re: Fork Seals
« Reply #2 on: July 07, 2026, 12:56:53 PM »
Just keep a close eye on it. If the seals are leaking there will be a film of oil on the chrome stanchions just above the dust covers. If there is an oil leak on the bottom of the fork sliders it could be coming from the bottom fork bolt. Keep checking.
Offline Otis
Re: Fork Seals
« Reply #3 on: July 07, 2026, 01:19:48 PM »
Many many thanks for those two helpful replies.
I will monitor it closely but its slightly odd that the seepage should have occurred in a one off situation. Perhaps the seals are weak and perishing so whilst it shouldn't happen under max compression, perhaps it did and is a sign that they are going to fail soon.
From the records I have they were replaced 2000 miles ago but that was nearly 20 years ago!!
Graham
1972 Honda CB350F
1997 Ducati ST2
Re: Fork Seals
« Reply #4 on: July 07, 2026, 04:19:48 PM »
Was it one leg or both? Worth lifting the dust covers to see what the condition is like underneath.
Offline Otis
Re: Fork Seals
« Reply #5 on: July 07, 2026, 05:35:35 PM »
Yes, in fairness it was just the one leg on the Offside.
Graham
1972 Honda CB350F
1997 Ducati ST2
Offline Otis
Re: Fork Seals
« Reply #6 on: July 07, 2026, 05:36:48 PM »
Is that possible without dismantling the fork?
Graham
1972 Honda CB350F
1997 Ducati ST2
Re: Fork Seals
« Reply #7 on: July 07, 2026, 10:21:16 PM »
Yes, dust covers should just pop up.
Offline Otis
Re: Fork Seals
« Reply #8 on: July 27, 2026, 05:27:29 PM »
This is still a bit of a mystery to me. Is there any way of testing the fork performance to see if they are as expected without having to strip down?
Graham
1972 Honda CB350F
1997 Ducati ST2
Online McCabe-Thiele (Ted)
Re: Fork Seals
« Reply #9 on: July 27, 2026, 07:00:33 PM »
Might be worth draining the fork oil, measure the volume from each side for comparison.
Check the condition, refill with correct volume of oil.
If fork oil  is badly contaminated, be worth rebuilding them.
Offline Otis
Re: Fork Seals
« Reply #10 on: July 27, 2026, 09:43:41 PM »
Thank you.
Much appreciated advice.
Graham
1972 Honda CB350F
1997 Ducati ST2
Re: Fork Seals
« Reply #11 on: July 28, 2026, 12:18:35 AM »
With oil in you can push down and see if there is resistance to travel both ways, apart from that no test.
Any leak of liquid is an mot fail, oil mist is allowed
Re: Fork Seals
« Reply #12 on: July 28, 2026, 02:37:21 AM »
Personally when I was an MOT tester I’d most likely have failed it for oil mist, if it was enough to leave a ring I would have wondered how long that had been leaking like that and how much that loss of oil would have degraded the suspension. Saying that, I was a bit of a soft touch back then and I would have just pointed it out and said fix it asap. Depends how bad it looked.
Offline ST1100
Re: Fork Seals
« Reply #13 on: July 28, 2026, 08:33:09 AM »
Well, its progressing...
On my '00 ST both fork seals failed shortly one after another while up in Norway... they do have some nasty roads up there...
So I grew the routine of rinsing down rotors, calipers & pads with brake cleaner twice a day...
By the time we made it back home (Austria) both fork bottoms were FUBAR at the inside/bore...  :-\
STOC #637
Re: Fork Seals
« Reply #14 on: July 28, 2026, 09:11:17 AM »
They do sometimes just quit after looking and earning fine for many miles. Possibly through rubber ageing at a guess.
Think I'd have tried to make some little towelling catch devices to keep the oil from running down in that situation. A little like those Bjorn Borg era wrist sweat band things.
You'd need to stop yourself getting caught up in the whole headband and "Fame" type leg warmers though  ;D ;D
With MTB forks (up to 40mm stanchion available) its considered reasonable to flip the bike (usually to install wheels after transit in car) and pump the forks a couple of times to keep the fork seals from running dry after storage period.
Difficult on a ST 1100 though  ;D
