General > Out & About
London buses
<< < (5/5)
TrickyMicky:
I worked for London Transport for nearly 11 years in Romford. 3 years as a conductor, then passes my test in a RTW with a pre-select gearbox. One of my best ever jobs.  The final 28 years of my working life I was a coach driver.  Attached (hopefully!) is the actual bus that I leant and took my test in.  (RTW 62)
Bryanj:
Those vrt were wonderfull machince as long as you could keep bevel boxes in them, and the early gardner engine ones with air throttle were real.fun to.reverse
Oddjob:
There’s a picture on eBay showing a SELNEC southern British Leyland PD2 on a 192 bus service, which was run by both the Manchester and Stockport depots. I spotted it one day and was amazed to see the conductor standing at the side was actually me in around 1975. I bought the pic, even recognised who the driver was. There was another of the same type bus on the 316 service and it’s me driving with my normal conductor stood talking to me on the stand.
Your bus is a lot like the Leyland PD2 Tricky, very similar. Only ever drove one pre-select, we didn’t have any at our depot. Wicked things if you got the gear change wrong, used to jam your leg into the steering wheel when it kicked back.
Laverda Dave:
--- Quote from: TrickyMicky on August 10, 2026, 11:26:40 PM ---I worked for London Transport for nearly 11 years in Romford. 3 years as a conductor, then passes my test in a RTW with a pre-select gearbox. One of my best ever jobs.  The final 28 years of my working life I was a coach driver.  Attached (hopefully!) is the actual bus that I leant and took my test in.  (RTW 62)
--- End quote ---
Nice bus Micky. My brother part owns (and drives a 1948 vintage RT in London Country colours). Working for LT you probably used to buy 'Griffin Home Sales'. This was food made at the LT Croydon food factory. They used to sell tea bags, sausages, huge shortbread biscuits the size of a side plate with a Griffin stamped in the middle. My ex-wife's sister had her wedding cake made there. All gone now in the name of privatisation and 'efficiency'.
Orcade-Ian:
When I started at High School in 1960, I had to get a bus into Hull Paragon Station, then another (usually a trolley bus) to the School and the same on return.  I saw bigger lads jump off the bus platform and then run alongside to save a bit of time.  "I'll have some of that" thought I, but my next bus departed from the opposite direction.  I had obviously not worked out the physics, as I jumped down and promptly fell flat on my arse, to the great amusement of everyone watching!  I did perfect the technique eventually, until the Atlanteans came along with folding doors at the front, under the watchful eye and control of the driver.
Ian
Navigation
[0] Message Index
[*] Previous page
Go to full version
