SOHC.co.uk Forums > CB350/400
Exhausting mystery.
exvalvesetdabbler:
Save that thought for those that pretend to run our country :)
Ken4004:
Hi Athames57
If your interested I have one of these brackets spare, I was going to put it on EBay but have not got around to it yet.
Please see photos attached regards Ken
Athame57:
Hi Ken
PM'd you!
Laverda Dave:
If you fit the OE bracket George are you going to fit the OE packer/seal in the silencer to collector box? I can see the Thuruxton silencer you currently have fitted is straight, fitting the OE bracket may angle it slightly upwards opening up the joint between the silencer and the collector box and this will require a packer gasket otherwise the joint could end up blowing.
You can get the packer on eBay a lot cheaper than Honda OEM.
Athame57:
--- Quote from: Laverda Dave on August 18, 2026, 03:55:13 PM ---If you fit the OE bracket George are you going to fit the OE packer/seal in the silencer to collector box?
--- End quote ---
Yes Dave. I have actually got that item right here, erroneously bought when I got the new downtubes and collector box with it's fittings. The clamp I have also as the Thruxton one is smaller.
Navigation
[0] Message Index
[*] Previous page
Go to full version
