Author Topic: CB550 Points - Arrrrggg  (Read 4537 times)
Re: CB550 Points - Arrrrggg
« Reply #15 on: September 23, 2026, 08:05:10 AM »
Max gap 1+4 points will be when the advancer shows the position in the pic. For 2+3 points crank 180o clockwise.
« Last Edit: September 23, 2026, 08:09:00 AM by deltarider »
Online McCabe-Thiele (Ted)
« Reply #16 on: September 23, 2026, 09:48:25 AM »
I made an expensive error the first time I tried to set my 500 points.
I convinced myself that the central lobe must be worn as I just could not get the 2-3 points set correctly.
As the centre bolt was in poor condition I bought a DS replacement lobe and bolt.
Of course it made no difference at all, I replaced the Tec base plate that came with good Tec points from Steve at 400 spares. I set them without any difficulty. My plan was to change to electronic ignition once the 500 was run in, I'll stick with the points this time.
Offline JezzaPeach
  • CB500/4 K1 1972 gold
« Reply #17 on: October 10, 2026, 08:12:17 AM »
This may already be addressed in the answers, but I had the problem with running out of adjustment, and it should be easily fixed by changing the gap because that makes a big difference in the rotation of the plate. I think in my case I made the gap on the smaller side.
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
