Author Topic: Tacho bug  (Read 3938 times)
Offline Athame57
Tacho bug
« on: October 01, 2026, 08:08:41 PM »
I've had a wasp in my helmet a few times and a spate of grasshoppers hitching a ride all summer once, but now  a new one.
I have a Ladybird residing in my tachometer, I'll try to get a pic. It keeps crawling around the face of it while under way, the needle passes over it so it isn't getting hurt but it is a damn distraction!  :o I thought these things were supposed to be sealed units? Anyone got a suggestion, please don't mention insecticide!
1978 CB400F2 named Elen.
Re: Tacho bug
« Reply #1 on: October 02, 2026, 08:40:18 AM »
I suspect the bulb holder is the easy way in, especially if the boot has deteriorated.
Re: Tacho bug
« Reply #2 on: October 02, 2026, 11:04:51 AM »
You're going to need a spider, JIS standard too :)
Could trun into a "I knew an old lady that swallowed a fly" fable though.
Offline exvalvesetdabbler
Re: Tacho bug
« Reply #3 on: October 02, 2026, 01:01:19 PM »
No spiders, I had one set up home in my Speedo when it was off the bike.
How about a match stick, a couple of inches of thread with a couple of greenfly on the end. Then dangle it near the hole and wait.
Best outcome is if it expires, falls to the bottom and gets captured by some stray grease.
Regards
Dave
Offline Athame57
Re: Tacho bug
« Reply #4 on: October 02, 2026, 02:49:07 PM »
Thanks for the advice guys, I'll consider my options,  ;)  here is  the prisoner in the clock!  :o
Offline Rayzerman
Re: Tacho bug
« Reply #5 on: October 02, 2026, 03:27:02 PM »
Maybe try a vacuum via the bulb port??
'72 CB350F, 2010 CBF1000FA
Offline Athame57
Re: Tacho bug
« Reply #6 on: October 02, 2026, 04:48:38 PM »
Now THAT sucks!  ;D   I'd have to hunt through the hoover bag to confirm, and bring my bike upstairs to have the hoover reach it!  :o
Re: Tacho bug
« Reply #7 on: October 02, 2026, 05:59:53 PM »
Presumably the Ladybird has started to go into it's winter dormant stage.
When it wakes it will either find it's way out or perish. The remains will fall to bits, unlikely to damage anything.
Offline Athame57
Re: Tacho bug
« Reply #8 on: October 02, 2026, 07:26:45 PM »
Well, for the time being lets see the bright side, she is colour matched to the bike!  ;D
« Last Edit: October 02, 2026, 07:34:50 PM by Athame57 »
Re: Tacho bug
« Reply #9 on: October 03, 2026, 09:28:50 AM »
Definitely caught the “bug”! You’re going to be limited to 5k or she’s going to have to hang on. Of course it might move. You wouldn’t want it jammed up in the intricate workings of the gauge, don’t know if that’s possible haven’t studied inside of these.
Offline Athame57
Re: Tacho bug
« Reply #10 on: October 03, 2026, 09:46:29 AM »
Your concern is misplaced Johnny, the needle clears her head, neck and shell. She will not be pushed around  the clock nor will she do an Anne Boleyn!  ;D
Re: Tacho bug
« Reply #11 on: October 05, 2026, 08:45:41 PM »
Well, being an animal lover (no matter what shape and size) I personally would take the tacho off the bike, remove the instrument lights and place it on edge in a large plastic food bag and keep an eye on it. If the ladybird comes out you'll see it in the plastic bag. It appears the ladybird found it's way onto the dial face by crawling through the gap between the tacho face and the side case so it should crawl back out the same way...... eventually!
Offline Athame57
Re: Tacho bug
« Reply #12 on: October 06, 2026, 07:43:37 AM »
Hello Dave
It has actually done a vanishing act, hopefully a case of 'Ladybird, ladybird fly away.....' :D
Re: Tacho bug
« Reply #13 on: October 06, 2026, 08:08:16 AM »
Could be round the back and laying eggs by the odometer  :D
There may be a herd ( what's collective noun for ladybird? ) next spring, then you'll have to farm aphid to feed the family  ;D  ;D
Offline Athame57
Re: Tacho bug
« Reply #14 on: October 06, 2026, 10:08:46 AM »
I'll let you know in spring!  ;)
