Author Topic: CB550 Tuning Advice  (Read 2391 times)
Re: CB550 Tuning Advice
« Reply #75 on: October 21, 2026, 05:18:32 PM »
Aah! The choke on any carburettor is described as ON when its restricting airflow by shutting off the incoming air. That's it's starting/cold position.
Choke OFF is with the restriction of incoming air least affected. This is normal/warmed up running position.
Offline Neilw
« Reply #76 on: October 21, 2026, 05:19:30 PM »
Just to make sure: when the little chokelever is horizontal the chokeflaps are down (to facilitate cold start), when the lever is vertical the chokeflaps are up (engine warmed up).
One simple question (Thank you), and now i get this :-)
https://youtube.com/shorts/rqzMJKfwX5I?feature=share
A bit of white smoke.
Haven't tried with choke on :-)
Got it idling with throttle screw adjustment.
That's me done for the day, now feeling very happy i've heard it running.
Thank you so much for bearing with me.
« Last Edit: October 21, 2026, 05:21:54 PM by Neilw »
« Reply #77 on: October 21, 2026, 05:38:17 PM »
On is when butterflies close off the hole, off is when theyare horizontal i.e. hole open
« Reply #78 on: October 21, 2026, 06:20:50 PM »
That sounds really good in the yt clip Neilw.
Bang on the money for carb balance, so much so that I wouldn't change that at all.
From an interest point of view to us out here, a clip of it with gauges hooked up to show what they read would be interesting. But I'd not change the balance set you've got  .... even if the gauge suggest any variance.
Well done with tbe detailed work, very frustrating at times, isnt it? That's very good progress there that you've got too.
"White smoke " is just vapour from combustion before the cylinders and exhaust have got fully warmed through. That'll disappear when fully up to temperature, perfectly normal from cold start in engines.
« Reply #79 on: October 21, 2026, 08:57:16 PM »
Now bring the rpm down to say 1150 and then let us judge the sync.
Offline Neilw
« Reply #80 on: Today at 10:14:05 AM »
Cold start this morning with the Choke on. Wouldn't start unless i blipped the throttle, and then would only stay running if i held the throttle open, which i did to warm up the bike.
I then switched the choke off (down position), and the bike immediately started running smoothly. I let it run for a while, it spat once or twice and then died about a min later. Started immediately without choke and idled quite happily with a few spits.
https://youtube.com/shorts/DL4JK8qOT2g?feature=share
Idling at 1200 rpm thereabouts.
I don't think i'll be taking the carbs off now, so I'm going to put the airbox back and air filter to see what this does.
Other than the throttle screw i've changed nothing - airscrew is still 1.5 turns.
« Reply #81 on: Today at 11:09:27 AM »
It may not be cold enough ambient to need full choke at this time of year in starting it. Worthwhile trying at 1/2 to judge effect.
Many bikes of this era have no throttle interaction with "choking" application, its just down to you to open the throttle a little, as appropriate, to balance demands at this cold start phase of running bikes like this. That's entirely normal and expected.
The end of line SOHC models variously had the throttle and choke linked to give the effect that you're doing manually here.
It does sound particularly good in running and cylinder to cylinder parity. If anything, it's "hunting" slightly (a little excess fuel at that independent running point) which is detectable in minor way.
A couple of miss/stumble hiccup heard, likely to be the plugs having not fully warmed from riding out on it (typical if just standing with no load ) that should disappear when all up and running.
As you note, fully assembled intake system to be installed, then see what you've got at that point.
It is very smooth though. Any competent workshop would be proud of that result.
« Reply #82 on: Today at 11:14:22 AM »
The 500/550 with those carbs need choke on to start but almost immediately back to half after starting and fully off fairly quickly, unless you are trying to ride in sub zero temperatures and i for one am too damned old for that!
Offline Neilw
« Reply #83 on: Today at 11:49:28 AM »
Lol, this bike will only see summer temps, no cold or wet riding for me!
