Author Topic: CB750 sohc K5 head skimming?  (Read 363 times)
Offline martin_uk
« on: October 12, 2026, 07:41:35 PM »
Helping a friend with his bike and depressions have formed where the head gasket combustion rings contact the head.
I have not come across this on my CB750 bike rebuilds and would appreciate views and experience.
Is it OK to lightly skim head and what is limit?
Has anyone experienced this before and likely cause?
The combustion rings on new gasket will help seal the extra gap caused by grooves, but what is the limit?
Views and thoughts appreciated.
1977 CB750F1
1978 CB750F1
1975 CB500K3
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Re: CB750 sohc K5 head skimming?
« Reply #1 on: October 13, 2026, 03:28:37 PM »
To me that has been overtightened, personaly i would ask Mark Paris(hondaman) on the us forum as to maximum skim
Offline martin_uk
« Reply #2 on: October 13, 2026, 05:04:34 PM »
Thanks Bryan
1977 CB750F1
1978 CB750F1
1975 CB500K3
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Online McCabe-Thiele (Ted)
« Reply #3 on: October 13, 2026, 05:44:29 PM »
There were some marks on my 500 cylinder head, difficult to measure the depth of the imperfections, one was where the main seal ring is for the cylinder head.
Local machinists said they would take the minimum required to remove the marks. When I picked up the head the finish was like a mirror.
I asked how much material had been skimmed, less than 5 thou of an inch!
The firm are known locally  primarily as diesel fitters & engineers.
Service Garage Borrowash.
They have a website now.
Offline martin_uk
« Reply #4 on: October 15, 2026, 09:58:38 AM »
Thanks to Bryan's suggestion, asked question on US site.
General consensus is that original head is 72.2mm (also 72.18 mentioned) thick and light skim would not be an issue.
Cylinder original thickness 84.78mm
However, careful measurements of locating dowels (knock pins) and seals needed, with reductions as necessary.
If after skim the dowels are then longer than total recess (cylinder + head), plus compressed head gasket it would stop head fully seating.
Also potential cam timing issues if more head face or cylinder top removed.
Please double check from other sources before relying on this.
See post here https://forums.sohc4.net/index.php/topic,207323.0/topicseen.html
1977 CB750F1
1978 CB750F1
1975 CB500K3
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
« Reply #5 on: October 15, 2026, 11:17:26 AM »
You are welcome martin, ive been following the topic over there as well
