Author Topic: Failing coil  (Read 604 times)
Offline Ken4004
  • Semi retired hiding from wife in shed
  • Triumph Tiger sport 2013. Honda CB 400 4
Re: Failing coil
« Reply #15 on: October 15, 2026, 03:52:55 AM »
Just found this spark plug tester on eBay, not sure if it’s any good but it looks like a fairly basic device so it’s probably OK.
Re: Failing coil
« Reply #16 on: October 15, 2026, 06:24:00 AM »
That does not test the spark plug it test wether the coil is giving a good spark
Re: Failing coil
« Reply #17 on: October 15, 2026, 09:21:54 AM »
Put a spare plug in a lead  and start it with that held to earth, will verify you've got coil output.
Re: Failing coil
« Reply #18 on: October 15, 2026, 11:19:08 AM »
Better if you remove the cap and see how far the spark will jump from ht lead to head, from old memory 3-4mm is a minimum
Offline Ken4004
Re: Failing coil
« Reply #19 on: October 15, 2026, 11:21:02 AM »
Yes you are correct I meant to say coils , sorry for the confusion
Offline Athame57
Re: Failing coil
« Reply #20 on: October 15, 2026, 05:04:20 PM »
I've dug up a coil from the depths of my spares pile and fitted that, all is now fine.  ;D While the spanners where out I put a new starter solenoid in too  ;) as issues had started with that as well.
I brake for animals!
1978 CB400F2 named Elen.
Re: Failing coil
« Reply #21 on: October 15, 2026, 05:49:39 PM »
Could you see any visible cause on the coil you changed such as casing cracks or HT leads cracks?
Offline Athame57
Re: Failing coil
« Reply #22 on: October 16, 2026, 02:28:14 PM »
I binned it without really looking for those things, the pic is of a different coil, but I did notice something else. The two rectangular protrusions ( I don't know their name) on each end I thought were solid things but are actually many leaves pressed together. When unbolted from the frame these leaves splayed and showed rust. Maybe oxidation caused the failure?  :-\
« Last Edit: October 16, 2026, 04:18:21 PM by Athame57 »
Offline Ken4004
Re: Failing coil
« Reply #23 on: Today at 06:36:05 AM »
It’s a shame you threw the old coil away I would have liked to have tried to repair it just as a matter of interest.
People would say why bother but I like to know how things fail and why .
If anyone has any coils they are going to junk please let me know thanks on advance.
Offline Mikep328
Re: Failing coil
« Reply #24 on: Today at 10:51:18 AM »
"there have been reports of someDyna units failing, and thats the originals not the knock offs"
Original coils failing after only 50 years...You'd think Honda would have used some decent quality parts!  ::)
Mine:
1976 CB400F
1973 Norton 850 Commando
2015 BMW R9T
2017 BMW R1200RS
2021 Moto Guzzi V7 Special
Wife's:
2015 Ducati Diavel
2019 Honda Africa Twin
2019 Honda NCT750
Offline Athame57
Re: Failing coil
« Reply #25 on: Today at 11:20:41 AM »
Interesting, DSS are offering new coils the same as the originals by the original manufacturer. At £74.00 not cheap and without the mounts, but they sound like an investment, I'm tempted.
Re: Failing coil
« Reply #26 on: Today at 11:58:33 AM »
I have Dyna S coils on my 400, benefit is you can easily replace a lead.
I fitted Hedler coils to my 500 as the leads were toast.
My BiL recommended their electronic ignition system.
I've never understood the logic in the leads being part of the coil.
The DS coils do look a good long term buy.
Offline Athame57
Re: Failing coil
« Reply #27 on: Today at 02:36:21 PM »
Perhaps a case of built in Functional obsolescence? It shifts units for them! ;)
Re: Failing coil
« Reply #28 on: Today at 03:39:55 PM »
Its cheaper ted, same as phillips(jis) screws, pennies per bike but millions in production
