Author Topic: Carb Welding  (Read 1146 times)
Offline tom400f
Carb Welding
« on: October 27, 2026, 04:38:09 PM »
I have managed to crack the idle mixture screw orifice - breaking a bit off. This happens to be on a 1997 VFR750 carb but imagine that is irrelevant.
I feel like it should be possible to weld this back in place. Does anyone know of such a service they might recommend? There is a thread inside, obviously, if that would complicate matters.
Thanks if you know!
1978 CB400F2 Yellow
1997 VFR750FV Lapis Blue
2010 VFR800 A9 Silver
2013 Yamaha FZ8 Grey (Son's)
Re: Carb Welding
« Reply #1 on: October 27, 2026, 04:44:49 PM »
Probably cheaper to either buy a new bank of carbs or just that single carb tbh.
Re: Carb Welding
« Reply #2 on: October 27, 2026, 04:48:12 PM »
There was somebody on the us site doing laser welding i think but havent heard of anybody over here
Offline Orcade-Ian
    • Older Vehicle Web
Re: Carb Welding
« Reply #3 on: October 27, 2026, 05:12:56 PM »
As the others say, probably best to source another - single if poss.  There is a great guy on here Roo, (laverdaroo) he got up to his neck repairing a VFR - might be worth asking (pm) if he has any spares or sources for same.
Ian
1972 Honda CB 350/4
1975 Honda CB 550/4 F1
1976 Honda CB 400/4 F1
2020 Honda C125 Super Cub
2026 Honda ADV 350
Re: Carb Welding
« Reply #4 on: October 27, 2026, 06:30:36 PM »
Roo has internet problems so he may not answer for a few days, bear with him.
Offline tom400f
Re: Carb Welding
« Reply #5 on: October 30, 2026, 12:05:43 PM »
Great replies all.
You would probably not be surprised what people want for a ropey set of carbs for any bike, tbf. I'm not in the carb restoring business but I bought a very expensive ultrasonic cleaner from Germany and a reasonably priced set of carbs to practice on. While this wasn't the original plan thought I could sell them refurbished to get some of that expense back!
Did successfully do my originals, so this isn't urgent. Been stalking ebay and every one apart from no. 4!
Sounds like welding is not an option 😑
1978 CB400F2 Yellow
Re: Carb Welding
« Reply #6 on: October 30, 2026, 02:16:14 PM »
Carbs are usually cast using a kind of zinc alloy so it can't be welded. There is a low temperature aluminium 'weld' stick available called Durafix. It is more like a solder and melted with a propane torch or similar. With care it might work on your carb and then retap the thread for the idle mixture screw.
Offline scottly
Re: Carb Welding
« Reply #7 on: October 30, 2026, 04:43:23 PM »
That would be member Jim F who does the laser welding on carbs, but with the cost of shipping in both directions it wouldn't be worth it.
Seeley SH7-521 owned since 1979
