Author Topic: Changing sprockets on a CB400F to give a more relaxed ride?  (Read 260 times)
Offline Rural Rider
  • Just back to biking after 35 years
« on: November 06, 2026, 12:32:34 PM »
Hi experts 🙂
I'm thoroughly enjoying riding a 1975 400F again, although I think my days of chasing the red line are probably behind me!
Has anyone changed the front or rear sprocket to make the bike a little more relaxed at cruising speeds please?
Only a thought at the moment, but I am wondering if this works in practice and, if it could cause any additional stress on the engine or gearbox or affect reliability in any way.
I know the 400F was designed as a bit of a mini café racer, but these days its home is trundling around the rural back roads of Northumberland, which suits me just fine.
Very interested to hear from anyone who's tried it.
Adrian
Offline Athame57
Re: Changing sprockets on a CB400F to give a more relaxed ride?
« Reply #1 on: November 06, 2026, 01:40:58 PM »
I've always associated this sort of modification with the opposite object in mind. If the sprockets you seek are to be found, I would be worried about the engine being worked laboriously myself. Why not just fit US spec bars for a more laid back ride?  ;)
I brake for animals!
1978 CB400F2 named Elen.
Offline Rural Rider
« Reply #2 on: November 06, 2026, 02:46:00 PM »
Hi, thanks for the reply.
I tilted the bars back just slightly, and it’s made a noticeable difference to the riding position, without needing to fit the longer US-spec cable kit. 🙂
Engine lugging is definitely something I’ve been considering, particularly as the CB400F engine was designed to rev so freely. I wouldn’t want to compromise that characteristic too much by going too far with the gearing changes.
Adrian
Offline Athame57
« Reply #3 on: November 06, 2026, 03:35:11 PM »
In case you havn't already, test the lock of the bars. With me the left hand switch gear connected with the tank ...chip chip. ::)
« Reply #4 on: November 06, 2026, 04:05:19 PM »
Unfortunately the 400 is a revy beast and i think if you change the sprockets the engine just will not pull the speeds you want
Offline Rural Rider
« Reply #5 on: November 06, 2026, 06:31:45 PM »
Thanks. Just been down to check and I have at loads of clearance at full lock. We may have different bars ?
Offline Rural Rider
« Reply #6 on: November 06, 2026, 06:40:29 PM »
Thanks.
Not really looking for speed & rarely get past 60 mph these days when out for a pootle.
Was an interesting idea but now thinking it may strain or labour the engine with even a minor change ?
Will consign this one to the "theoretically possible but not really practical" file :  )
Offline TrickyMicky
« Reply #7 on: November 06, 2026, 10:41:59 PM »
When you consider that on the standardgearing, in 6th gear it's approximately 1,000RPM per 10MPH, so at 70MPH in top it's just starting to breathe properly. If you raise the gearing by any amount you will find 6th gear virtually unusable.  Don't be fooled by the rather low 1st gear, this just bgets you on the move without destroying the clutch.
