Author Topic: 5.5mm Genuine Honda Fuel Hose  (Read 1732 times)
Offline martin_uk
« on: November 08, 2026, 10:13:35 AM »
Had a search but could not find mention on here.
I have previously used the genuine Honda pipe on my CB750 and it is expensive, but IMHO seems better quality and has a smaller OD.
DS have at £22.20 per metre plus P&P and Shire bikes at just under.
The pn for bulk hose is 95001-55008-60M  for 8 metres and only Japan sellers at around £70 showing which is subject to VAT/handling on import.
Fowlers list at £175 special order  :o
Alternatives seem to be either 5mm or 6mm and have larger OD.
Julie recommended Planet Silicon but don't list the 5.5.
Before I bite the bullet and order from DS or Shire, would be interested in thoughts and other suppliers
I would consider buying from Japan if it was viable and also use on other Hondas I have  :)
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph Street Triple 675R
Ducati 800 Icon Scrambler
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
Offline martin_uk
Re: 5.5mm Genuine Honda Fuel Hose
« Reply #1 on: November 08, 2026, 10:16:54 AM »
Sorry, Shire bike is £22.80 pm inc P&P
So maybe a better bet than DS unless I have other stuff from DS to combine postage
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
« Reply #2 on: November 08, 2026, 10:35:56 AM »
I bought some fuel pipe from planet silicone a while back for my 500, it went quite soft in a short space of time, as I had to remove the Carbs due to issues caused by my temporary petrol tank I replaced it as I wasn't comfortable with how floppy it was. I used Gates as that what had been fitted by Gerben, when it comes to replacement pipe I'll only buy genuine Honda from a reliabe source.
As long as the pipe from Shire Bikes is genuine Honda and not a copy, not sure if the genuine pipe has markings. Meanwhile my 400 pipe has gone quite hard since I fitted it in 2020/21 - it was not genuine, I will replace it with DS genuine pipe next spring.
« Reply #3 on: November 08, 2026, 11:22:39 AM »
How has the Gates pipe performed, Ted?
« Reply #4 on: November 08, 2026, 01:30:26 PM »
So far it's been good, only potential issue is it's a tad thicker so I/d is a tight fit through the carburettor bracket.
I always use a pipe clip.
Update PS I do like the idea of the Cohline pipe that will withstand E100, not sure what the o/d is..
« Last Edit: November 08, 2026, 03:18:25 PM by McCabe-Thiele (Ted) »
« Reply #5 on: November 08, 2026, 01:33:18 PM »
I imported some direct from Japan, genuine Honda part, if i have a length left its £12 per meter plus postage
Offline neat street
« Reply #6 on: November 08, 2026, 01:35:45 PM »
I have had some of Brians fuel pipe and it is perfect :-)
CB500 1975
CB750F 1976
KLX250 1983
Lambretta SX200 1979
Mini Mayfair 1984
Offline Skoti
« Reply #7 on: November 08, 2026, 04:22:30 PM »
Bought a meter from DS, then got more from BryanJ on this forum at half the price.
https://www.davidsilverspares.co.uk/tubes/
Also using it on other makes of classic and vintage stuff as well, very flexible and never hardens, just like Honda intended it to be.
« Last Edit: November 08, 2026, 07:19:16 PM by Skoti »
Skoti
1976 Honda CB750F1
Offline martin_uk
« Reply #8 on: November 08, 2026, 04:31:22 PM »
PM sent
1977 CB750F1
1978 CB750F1
1975 CB500K1
Triumph 3TA
AJS 350 mod16
BSA BantamD1
Honda C90zz
« Reply #9 on: November 08, 2026, 05:04:06 PM »
I imported 10 metres a year or so ago. Haven’t sold any due to illness so around 8 metres is available to buy if needed. Same price as Bryan as that’s about what it costs with import duty etc.
Offline Anderzander
« Reply #10 on: November 08, 2026, 11:46:02 PM »
What kind of clips do you use with the 5.5 mm hoses ?
CB750 K3
Offline Skoti
« Reply #11 on: November 09, 2026, 06:54:56 AM »
Original style Honda wire clips 95002 02100.
https://www.cmsnl.com/en-gb/products/clip-b10-tube_9500202100/
Can also be bought from your local Honda bike dealer or Honda garden equipment shop.
The fuel hose is a nice push on snug fit and actually barely needs clips, but better safe than sorry.
Good luck.
« Last Edit: November 09, 2026, 08:53:33 AM by Skoti »
Skoti
1976 Honda CB750F1
« Reply #12 on: November 09, 2026, 06:35:05 PM »
To save multiple replies via the PM system I'll post here.
First off, pics of the fuel line I bought.
Clearly marked as genuine Honda fuel line.
Markings on the pipe.
It's rated as fine for Ethanol petrol up to E10, so at present in the UK it's E5 so fine for that. ID of 5.5mm and OD of approx 11mm.
So I've just opened the bag and cut off a 1m piece, it fits inside a Jiffy bag I have in stock. Tomorrow I'll take it to the Post Office and get a postal rate for that size envelope. I'll then advise everyone on the total cost. The bag is a little on the bulky side so may fail the letter box slot test the Post Office use to determine the postal rate. In which case it's goes up in cost.
And to the member who wanted some carb pins, yes I should have those somewhere and will throw them in with the piping.
After these sales I should still have 4 metres left.
« Reply #13 on: November 09, 2026, 08:18:56 PM »
Ken, from posting the same stuff it goes in the small parcel category as it fails the large letter test
« Reply #14 on: November 09, 2026, 11:44:51 PM »
I suspected that may be the case Bryan but I will see what the post office say first.
Now just 3 metres left unless I also sell the 2 metres I was saving for myself. I can always buy more. The import duty on this was a whopping £18.11 for some reason.
I may be wrong btw, I thought the package contained 10 metres but it may be only 8 metres long. I’ll have to start cutting it into 1m lengths and see how many I get out of it. Some listings have it at 10ft but it’s much longer than that looking at it. So I may in fact only have 1m left unless I sell the 2m I was saving for myself.
« Last Edit: November 09, 2026, 11:52:29 PM by Oddjob »
