Author Topic: Oil filter housing O Ring keeps blowing out  (Read 1062 times)
Offline Anderzander
Re: Oil filter housing O Ring keeps blowing out
« Reply #45 on: November 16, 2026, 08:15:12 PM »
I would recommend a borescope to check and clean out the galleries.
Whatever is in those galleries will go straight into your bearings when you start it up and my experience is that it take a lot to get them clean.
This wasn’t a CB engine (not even a bike engine in fact) but the last engine I rebuilt I had steam cleaned the galleries, put a paraffin gun through them, and blew them out with compressed air very thoroughly and the galleries were still full of chips (pic1). So I bought stainless brushes for cleaning gun barrels that fit onto a drill and ran those up and down, then wrapped the brushes in lint free microfibre cloth and finally they came clean (pic2).
CB750 K3
« Reply #46 on: November 16, 2026, 10:13:43 PM »
Hi Johny,
I dont know anything about your bikes history, your level of experience etc, so please forgive me for asking some basic questions about your rebuild, I'm not doubting your ability, I just do not know how experienced you are so please do not be offended by my questions, I am trying to help here.
Was the bike a runner when you bought it?
Do you think the engine casings have been seperated before?
TBH I can't see a bit of debris at one end of an oil gallery causing the oil filter housing seal to blow, there is a bypass valve in the oil filter housing to cater for a blocked oil filter, there is a pressure valve on the oil pump to regulate the maximum oil pressure.
if the oil pump valve was at fault, I would expect it to have been very difficult to remove the valve from the pump body, was it?
What are the crank case codes what colour shells did you fit?
Did you Plastigauge the crank shells for clearance?
« Reply #47 on: November 16, 2026, 11:39:47 PM »
I repeat the only thing that can cause excess oil pressure is a failed or blocked oil pump relief valve, there is nothing else to cause it
