New Unused OE parts.
Oil Filter 15410426010
3 off shim for filter spring 15414300000
Rear rubber for fuel tank 17613377000
Contact points 1&4 30203300154
Contact points 2&3 30204300154
Clip for fuel pipe. 950025000
Tool Bag 89101ME5670
Headlight bulb 34901388611
Rear brake rod pin 9501552000
Used OE Parts
Exhaust clamp collector to silencer. VG. 18372319300
2 off Ignition coils 30501300003 (Replaced in error, knackered condensors!)
Rear lifting handle , removed when carrier fitted.
2 off rear chain adjusters with bolts. 40543312010
2 off stoppers for above. (Hens Teeth!!) 52136333000
Rear wheel spacer RH 42313368000
Rear wheel spacer LH 42311286000
New unused pattern parts.
1 Set of 4 vacuum gauges.
Front brake reservoir cap.
Front brake pads DSS PPA13
Rear brake shoes. DSSPH315
4 off NGK D8EA plugs.
4 off carburettor top gaskets.
1 Set socket head screws for float bowls.
4 0ff clutch springs. 22401369.
The bike has now gone, and I don't want to bugger about selling bits here, there, and everywhere, so, the new OE parts alone retail at DSS for £143, I am asking £150 for everything, including postage. It's all boxed up ready to go.
