Author Topic: Indicator Switch Issue  (Read 161 times)
Offline Neilw
« on: November 18, 2026, 06:09:53 PM »
It's not a big deal in the scheme of things, but it is irritating, and I'd like to find a fix.
The indicators work, but if I push the switch to its limit left or right, the indicators stay solid. If I feather it back a bit, they will flash as normal, but it's a bit fiddly to do this while riding.
I cleaned the contacts and the bar the switch travels along; it's as if it goes past a stop position, but there isn't one.
How do I fix or adjust this?
Re: Indicator Switch Issue
« Reply #1 on: Today at 01:22:26 AM »
There is no adjustment and i can think of no reason it should happen
Offline Athame57
« Reply #2 on: Today at 07:36:51 AM »
If the switchgear is very old perhaps decades of use, especially by a heavy handed owner down the line, has worn extra travel into the housing? :-\
I brake for animals!
1978 CB400F2 named Elen.
« Reply #3 on: Today at 09:49:23 AM »
When you say the indicators stay solid do you mean they dont flash, are both bulbs illuminated?
I'm thinking this sounds like a bad earth, I've had issues with new bulbs being faulty in the past.
If both the front & rear indicators are on but not flashing, sounds like an earthing issue on the lamps or indicator circuit. Moving the switch back slightly might be creating a back EMF, this rise in voltage could then cause the poor earth to work.
The original earth's are imho less than perfect over time. I fitted earth wires from the bulb holders to ground in pretty much all of my bikes. Corroded bulb holders will also cause poor bulb earthing.
I can't remember how the bar switch circuit works, I would check  all the earths in the indicator wiring circuit including the flasher unit eart if there is one on your bike.
« Last Edit: Today at 07:33:28 PM by McCabe-Thiele (Ted) »
