Author Topic: Indicator Switch Issue  (Read 259 times)
Offline Neilw
« on: November 18, 2026, 06:09:53 PM »
It's not a big deal in the scheme of things, but it is irritating, and I'd like to find a fix.
The indicators work, but if I push the switch to its limit left or right, the indicators stay solid. If I feather it back a bit, they will flash as normal, but it's a bit fiddly to do this while riding.
I cleaned the contacts and the bar the switch travels along; it's as if it goes past a stop position, but there isn't one.
How do I fix or adjust this?
Re: Indicator Switch Issue
« Reply #1 on: November 19, 2026, 01:22:26 AM »
There is no adjustment and i can think of no reason it should happen
Offline Athame57
« Reply #2 on: November 19, 2026, 07:36:51 AM »
If the switchgear is very old perhaps decades of use, especially by a heavy handed owner down the line, has worn extra travel into the housing? :-\
I brake for animals!
1978 CB400F2 named Elen.
« Reply #3 on: November 19, 2026, 09:49:23 AM »
When you say the indicators stay solid do you mean they dont flash, are both bulbs illuminated?
I'm thinking this sounds like a bad earth, I've had issues with new bulbs being faulty in the past.
If both the front & rear indicators are on but not flashing, sounds like an earthing issue on the lamps or indicator circuit. Moving the switch back slightly might be creating a back EMF, this rise in voltage could then cause the poor earth to work.
The original earth's are imho less than perfect over time. I fitted earth wires from the bulb holders to ground in pretty much all of my bikes. Corroded bulb holders will also cause poor bulb earthing.
I can't remember how the bar switch circuit works, I would check  all the earths in the indicator wiring circuit including the flasher unit earth if there is one on your bike.
« Last Edit: November 20, 2026, 07:36:45 PM by McCabe-Thiele (Ted) »
Offline JezzaPeach
  • CB500/4 K1 1972 gold
« Reply #4 on: Today at 09:52:26 AM »
You could try buying another original one and look for differences and, rather than swapping parts over, design a fix trying to match the original. Then sell on the recent purchase.
It may be that yours is a copy so has slight differences allowing the lever to go too far.
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
Offline Neilw
« Reply #5 on: Today at 10:03:46 AM »
Mine is certainly original; I'm going to investigate the earthing, but I think the slider inside the housing is just sliding across too far and losing a full connection at each end. If that's the case i can just add a sleeve of heat shrink or something over the lever so it stops it from reaching the end of the electrical contact strip.
Offline bbrian66
« Reply #6 on: Today at 11:22:12 AM »
If the slider is going too far, would that not cause the indicators to go out rather than stay on? If so then it would more likely be the earthing issue.
