Author Topic: Indicator Switch Issue  (Read 335 times)
Online Neilw
« on: November 18, 2026, 06:09:53 PM »
It's not a big deal in the scheme of things, but it is irritating, and I'd like to find a fix.
The indicators work, but if I push the switch to its limit left or right, the indicators stay solid. If I feather it back a bit, they will flash as normal, but it's a bit fiddly to do this while riding.
I cleaned the contacts and the bar the switch travels along; it's as if it goes past a stop position, but there isn't one.
How do I fix or adjust this?
Re: Indicator Switch Issue
« Reply #1 on: November 19, 2026, 01:22:26 AM »
There is no adjustment and i can think of no reason it should happen
Offline Athame57
« Reply #2 on: November 19, 2026, 07:36:51 AM »
If the switchgear is very old perhaps decades of use, especially by a heavy handed owner down the line, has worn extra travel into the housing? :-\
I brake for animals!
1978 CB400F2 named Elen.
« Reply #3 on: November 19, 2026, 09:49:23 AM »
When you say the indicators stay solid do you mean they dont flash, are both bulbs illuminated?
I'm thinking this sounds like a bad earth, I've had issues with new bulbs being faulty in the past.
If both the front & rear indicators are on but not flashing, sounds like an earthing issue on the lamps or indicator circuit. Moving the switch back slightly might be creating a back EMF, this rise in voltage could then cause the poor earth to work.
The original earth's are imho less than perfect over time. I fitted earth wires from the bulb holders to ground in pretty much all of my bikes. Corroded bulb holders will also cause poor bulb earthing.
I can't remember how the bar switch circuit works, I would check  all the earths in the indicator wiring circuit including the flasher unit earth if there is one on your bike.
« Last Edit: November 20, 2026, 07:36:45 PM by McCabe-Thiele (Ted) »
Offline JezzaPeach
  • CB500/4 K1 1972 gold
« Reply #4 on: November 21, 2026, 09:52:26 AM »
You could try buying another original one and look for differences and, rather than swapping parts over, design a fix trying to match the original. Then sell on the recent purchase.
It may be that yours is a copy so has slight differences allowing the lever to go too far.
1972 CB500/4 K1 Gold
Wanted: my 500/4 UGP96M
from 1975-78. Garnet Brown.
Online Neilw
« Reply #5 on: November 21, 2026, 10:03:46 AM »
Mine is certainly original; I'm going to investigate the earthing, but I think the slider inside the housing is just sliding across too far and losing a full connection at each end. If that's the case i can just add a sleeve of heat shrink or something over the lever so it stops it from reaching the end of the electrical contact strip.
Offline bbrian66
« Reply #6 on: November 21, 2026, 11:22:12 AM »
If the slider is going too far, would that not cause the indicators to go out rather than stay on? If so then it would more likely be the earthing issue.
Online Neilw
« Reply #7 on: Today at 01:40:32 PM »
I had added a separate earth to the indicator and there is no change.
I tried adding heat shrink around the switch lever, but that just got jammed in the slot and wouldn't let me slide the switch.
I've taken some pics. The overtravel on the metal slider is about 3 mm at each end; it's where the white plastic connector passes over the end of the metal contact strip. As soon as it passes, the indicators go from flashing to steady on.
Now ChatGPT has suggested that I replace the flasher unit with something more modern which can handle voltage fluctuations better than the original. They are about £6 on Amazon; they are square in shape, not round like the original.
I guess this must be a result of component wear over the years. I either try and bodge something, replace the flasher unit or find a replacement switch, which I'm loath to do.
« Reply #8 on: Today at 01:52:26 PM »
Interesting findings, as one of my bikes has LED indicator bulbs I used a modern electronic flasher unit, some on the market have adjustable flashing rates, none are very expensive. Can't remember what shape mine is.
