Author Topic: Seat wobble  (Read 173 times)
Offline Anderzander
Seat wobble
« on: November 20, 2026, 10:26:38 PM »
Very basic question… as I’m new to the bike.
My seat has quite a bit of wobble - like the sprung pin latches but doesn’t pull down tight enough. With the seat lifted the whole spring bit wobbles quite a bit.
I also noticed that the two collars that fit inside the rubber bush are longer than the rubber bushes - so when it’s clamped up there is no tension on the rubbers to firm it up.
It’s only got 12k miles on it - and nothing looks worn .. so is that how they are ?
CB750 K3
Offline Athame57
Re: Seat wobble
« Reply #1 on: November 21, 2026, 08:20:37 PM »
It sounds like my loo seat was until I got someone else to fit the new one.  ;D I had some problems with my own CB400F because it was a non standard seat I had at first and when I got a standard (pattern) seat I had trouble locking it down. I found rubber stops associated with that first seat fitted to the frame were stopping things so I remove them and end up with the metal tongue at the seats front rubbing through the covering and scraping my tank. I eventually got it sorted out, that was about seven years ago though.
I think you might want to post some photos of the seat bottom and frame fittings for the CB750 buffs to look at?
I brake for animals!
1978 CB400F2 named Elen.
Offline Anderzander
Re: Seat wobble
« Reply #2 on: November 21, 2026, 08:37:04 PM »
Thank you - photos are a good idea. Maybe I can make a short video and link to it…. 🤔👍🏻
I’m just trying to figure out what’s normal. I’m thinking that the rubber may have shrunk ? and that’s why it’s just clamped on the spacer things …
I will return with pictures !
CB750 K3
Offline Anderzander
Re: Seat wobble
« Reply #3 on: Today at 02:19:39 PM »
No photos or videos - but I have resolved it.
Part nos. 11 - the rubber bushes, had I think shrunk in height so that when it was all tightened up the nuts clamped part nos. 12 between the seat base and the washers (part nos. 17)… leaving the rubber bushes and thus all of the locking pin to flex all over the place.
So, I just filed down the part 12 spacers so that they just sat below flush with the height of the rubber bush. Now with it clamped up the pin is properly bushed rather than just rattling around.
A lot less wobble.
There is play between the pins and the hinge tubes on the seat - no wear is visible though on either of them, so I think that’s a case of ‘they are all like that’.
« Last Edit: Today at 02:23:56 PM by Anderzander »
CB750 K3
