CB750
Help! - Rear Suspension Frame Mount
Topic: Help! - Rear Suspension Frame Mount (Read 5694 times)
pje750
Newbie
March 29, 2011, 09:33:24 PM »
Help, I could do with some advice - just sheared the mounting threaded stud on the frame where the top of the rear suspension connects. I'm assuming I'll have to drill out, helicoil and fit a new stud/bolt - does that sound right? will it be strong enough? Any advice gratefully received. Cheers
mick
Re: Help! - Rear Suspension Frame Mount
April 02, 2011, 10:19:47 AM »
Hi do you still have the post for the shocker to push on ?, if yes then all you have lost is the threaded part ?, you can drill and tap this part all it does is stop the shocker moving sideways, cheers Mick.
H2Eric
SOHC Member
April 02, 2011, 10:30:13 AM »
I would suggest that you remove whats left of the mount and have another mounting turned up on a lathe and welded in. I did this on my Suzuki GS750 after the previous owner for whatever reason had drilled through the mountings and just put a bolt through. Just drilling and tapping whats currently left of your mount may weaken it considerably.
Eric
April 02, 2011, 01:11:17 PM »
If you drill and tap then locktighte a stud in it should be OK but the best repair is as eric said
pje750
Newbie
April 04, 2011, 09:32:29 PM »
Thanks for the advice. My local motorcycle frame engineering place has drilled out and fitted a high tensile bolt. According to them, it will be stronger than the other side! lets hope so. Cheers. Pete
SteveD CB500K0
Administrator
Ride on the Steel Breeze...
April 05, 2011, 07:22:43 AM »
Add your location to your profile - then we won't have to ask "where are you?"
A local frame engineering place sounds interesting.
CB750
