General > New Member Introductions
New member and older motorcyclist
matthewmosse:
Hi, welcome to the forum. Depending on the finsh your happy with I've found sohc hondas way cheaper than my airhead beemers to run, but then I'm perverse and like rusty bikes and ride in all weathers using the bike as my only transport until it falls appart. (rebuild them then)
Spitfire:
Welcome to the home of the "money pits"
Den
meerkat:
--- Quote from: meerkat on April 02, 2011, 10:13:39 AM ---I recently bought a 1977 Honda CB400/4 F2 model and although very tidy and sold as 'fully restored', it needed a few jobs sorting.
Fork seals, wiring and the suspension being the main ones. The aftermarket rear units didn't fit, so they wouldn't work.
However I've bought a pair of Koni's which I'm fitting today.
--- End quote ---
Thanks for the welcome to the forum everyone.
An update - I fitted the Koni's and they really have made a difference to my ageing bones.
I now need to fit a better headlight bulb than the 35/35w which is not much use on unlit country roads.
Does anyone know if the generator and battery will run a higher wattage bulb ?
Thanks in anticipation.
florence:
There used to be a cibie replacement lens/reflector/bulb which was much better than the original fitting, I had one on my CB350 but essentially it's the same thing. It would save upgrading your electrical system.
Sadly the reflector on mine is now very rusty and needs replacing for the MOT. Does anyone know if these are still available and, if so, from where?
K2-K6:
I can't remember what size they are, 5 and 3/4 inches rings a bell? if so one of the best units I found for that size was from a Honda Accord car (one with 4 headlights) labelled same as the bike units "Stanley" H4.
They use a 55/60w bulb so you'll have to find out about that for this application and generator rating but the beam pattern I think is one of the best you can find and you may be able to get one from a car scrap dealer, think they may fit into existing rim/flange also.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
