CB750
Rewiring K2 with later high beam switch
3
4
Topic: Rewiring K2 with later high beam switch (Read 16661 times)
K2-K6
Re: Rewiring K2 with later high beam switch
Reply #30 on:
August 23, 2011, 11:18:19 PM »
I've never used anything but Blue Hylomar on these motors for all flat gasket surfaces and it always works.
Clean the surfaces with petroleum based cleaner, apply thin film of BH to entire surface, no excess though and let it dry for 15mins or so before assembly. If there are variance in flatness then coat both surfaces.
Don't know if you're using silicone? but I rarely use it on any engine as I just see it doesn't match the application unless specifically requested or the surfaces have such a poor alignment to need big gaps filling in.
Those Honda castings are usually quite good and I've not worked on one that I consider would need that amount of sealant.
This may be related to your oil flow problem, but I've often found silicone gasket material inside motors when stripping them as most of it squeezes out of the mating surfaces. It's not good, and once dismantled a Kawasaki Z900 that had an oil pick-up that looked like a pizza there was so much silicone on it.
With any cams I've always used a very fine graphited grease on all bearings and lobes to prevent pickup on any initial turnover, you don't need much but just enough to coat lightly each surface.
the-chauffeur
SOHC Member
Reply #31 on:
August 24, 2011, 12:02:11 AM »
I'll be using ThreeBond on the case halves. I generally use acetone to wipe down the mating surfaces and as far as I can tell, they're properly flat and not flawed. Which is a little more than I can say for some of the various sidecovers. I've been beset with minor leaks from those, too, and so this time I've taped some fine-ish wet 'n' dry (600-1000 grit) to a flat board and given the mating surfaces a rub over. That process revealed a number of high spots, which are no more - hopefully that'll put paid to the minor seeps.
But believe me when I say I'm having a run of extraordinarily bad luck with bikes right now, which includes:
- two water leaks from somewhere in the front outer case surfaces of my ST1100 (main transport). Looks like they are around the timing belt cover - the water pump housing sits behind the timing belt, so one of them may well be a rubber seal in that assembly; the other seems to be from somewhere around the front clutch cover, which makes much less sense. Whatever, it's a job that I have no desire to tackle myself right now (with the 750 already in bits) and is likely to be so expensive, it might be more than the bike's worth
- whilst admiring my newly powdercoated SL350 frame that I collected today, I've noticed a dirty great crack in the RHS swingarm spindle mount. I thought I'd got all of the anomolies on that frame sorted before I got it coated, but I guess not. Yes, it's structural so no, I can't simply patch it. I gotta get the powdercoat off and get it welded, then re-powdered.
If I didn't have bad luck, I guess I'd have no luck at all. Suffice it to say this
really
ain't my year.
the-chauffeur
SOHC Member
Not again . . .
Reply #32 on:
October 29, 2011, 09:49:52 PM »
I'm back . . .
I can't quite believe this. The 750 cases are leaking - again - from the same place as last time; the joint that runs across the part of the casing that separates the gearbox from the drive sprocket. Everywhere else on the crankcase joint is solid - no leaks from the front or other sides. As before, it's a tiny, tiny hole, but just enough so that as the crankcase pressure builds it lets out a small stream of oil. I really, seriously cannot understand why the leak has appeared - I checked and double-checked this area to make sure it was flat because of the last leak, and trowelled on the sealant in that area. Frankly, I had some concerns that I might have overdone it sealant-wise there, but nope - seems not.
Two observations: the lower casing has (very briefly) come into contact with a drive chain at some point in the long-distant past and there are a couple of shallow channels that are the chain width apart that run about 1cm across the join. And although I'm pretty damn sure the cases are the original matched pair, the lower case edge protrudes few fractions of a mm past the edge of the top. The leak is coming from somewhere between the channels, but the hole is soooo small, I'd need a microscope to see it (it's one of those where the oil doesn't stream out - it just kind of accumulates along the tiny lip and then runs off.
I've drained the oil and cleaned the sides up with white spirit and a cotton bud dipped in acetone. I've also run a couple of sharp tools along the area of the join to tidy it up. Bearing in mind the lengths I've gone to so far, and the lack of success I've had with this particular area, what I plan to do -
and I need some guidance here
- is to completely clean the area around the leak, (carefully) dry it out with a heat gun and then run a thin bead of JB Weld (metal epoxy) along the join. The US board is full of stories of folks who've used it to fill in/rebuild broken cases, so it seems the least destructive/best plan of action right now. Gasket sealant clearly isn't doing it, so I figure that before I pull the engine
again
I've got to try everything I can to try to cure that bloody leak - and carefully applying with something more substantial may be the answer.
On the subject of leaks, I think I've identified why my side cases have been leaking. After flatting them off and refitting them, I've found that no matter what type of gasket I've used (getting progressively thicker) they're still seeping - more from the front left than the rear left. But it dawned on me today that the leaks are from around the fasteners that fit inside locating dowels. What I guess is happening is that the side cases are being held very slightly proud of the engine faces by the dowels, and so even though I've spaced the sides sufficiently with thicker gaskets, they're not taking up the space the dowels create. So I s'pose I gotta shave the dowels down very slightly . . .
Thoughts on the joint issue very gratefully received . . .
K2-K6
Reply #33 on:
October 29, 2011, 10:23:04 PM »
I've no experience of JB weld so can't offer anything contructive or otherwise on that score, just some other general comments.
Fixing a leak from outside is usually marginal in almost any situation you can think of especially if pressure is high. This should be a low pressure location so odds are a bit better and with really good cleaning you may stop what appears to be almost a capiliary action, so on balance worth a considered effort.
Things like isopon filler stick really well to clean alloy and if not suitable can be very carefully filed away so very low risk.
Are you confident of any breather cleaning to help avoid crankcase pressure?
The dowels do have to be checked if you've reduced surafce level at all, bolt on without gasket and check with feeler gauge to get accurate read on it.
the-chauffeur
SOHC Member
Reply #34 on:
October 29, 2011, 11:20:28 PM »
Thanks K2.
Capillary leak sounds about right, and I know exactly what you're saying about external seals. I've been wondering about maybe v-e-r-y carefully filing/Dremel-ing a V shape into the join faces to create greater surface area for the epoxy to stick to, but decided to go with the flat for now on the basis that doing it this way is less invasive/more easily reversible.
Not quite sure what you mean about the breather but the pipe is new and doesn't have any snags or bends in it. I have, however, got a question about where the breather should join - something I've never properly understood. On my K2, the oil tank has 2 connections on the rear - one high up for a larger pipe, one lower for a narrower pipe. Right now, I've got the breather pipe from the cam cover going to the top connection on the oil tank; I've also got a small pipe running from the small lower connection to a similar size connector on the rear of the crankcases. But I don't know if that's right. Should it be closed circuit or should there be a breather-to-air? And if there is a breather-to-air, what are the connectors on the rear of the oil tank for?
And thanks for the pointer on the dowels - feelers are the way to go.
I'm sure I've asked for advice on this before
There are
UK Pete
Reply #35 on:
October 30, 2011, 06:10:02 AM »
Hi Niel, you have the patience of a saint, i would have smashed the f ing bike up with a hammer by now
Anyway, in part answer to your questions, i would say you have a good chance of success using an epoxy filler of some sort to stop your leak, i have used a 2 pack wood filler to repair a gaping hole in the side cover of a klr engine with great results, what happened is i fell off my KLR600 while trying to off road it and went tumbling down a bank, besides my injuries my bike had taken a beating, worst off all the gear change had gone through the engine casing making a 2'' crack just behind the magneto, as a very temporary bodge i cleaned the casing with thinners and run a small grove up the crack to open it out a bit roughed up the surrounding area cleaned again then filled with the epoxy wood filler which is almost identical to car body filler and reasonably flexible, that was 3 years ago and i use the bike every week it has held up really well and i have not been bothered to do anything more to it, so i recon it is worth you having a go, the JB weld is really good but a good 24 hours to cure, 2 pack epoxy is 20 miutes to cure and much easier to work with so there you have it nothing to loose really
Pete
Link to my Diecast K0 restoration
http://www.sohc.co.uk/index.php/topic,4827.0.html
Link to sandcast restoration
http://www.sohc.co.uk/index.php/topic,6862.0.html
the-chauffeur
SOHC Member
Reply #36 on:
October 30, 2011, 01:39:41 PM »
Hey Pete
I'm sure the expression
tortures of the damned
was invented just for me. It's unbelievably trying, but it feels soooo close.
I've gone with JB Weld because I'm not in any hurry, and I need whatever covers that area to set - solid. I decided to use the Dremel-thing which has got a kind of extension cable on it to get in and very, very carefully open the edges of the seal. After mixing the JB, I smeared it across the join, initially with a little paintbrush to try and get as good penetration as possible and then went over it with a finger. After getting as much into the gap as I could, I smoothed over the top (carefully) with a little white spirit. If it dries the right colour, it's going to be quite hard to see - except for the fact that there's no visible join.
While sorting that out, I feeler guage-d the side covers and found that two out of the three dowels were holding the side covers off by about 0.15mm, the kind of gaps that would need some fairly heavy duty gaskets to take up the slack. I've shaved down the dowels and checked everything was flat before refitting the side covers. Let's hope that's at least one step in the right direction.
Meantime, any thoughts on the breather hose locations? Something I forgot to mention earlier is that if I've run the bike and then open the oil tank while the oil's hot, it will hiss as the pressure escapes (not unlike removing a radiator cap from a hot engine, but nothing like as spectacular . . . ). I dunno, but that kinda doesn't seem right to me. And knowing that SOHC twins of the same age vent to air, I'm a bit concerned I might have introduced a closed system where there shouldn't be one . . .
UK Pete
Reply #37 on:
October 30, 2011, 01:44:25 PM »
That dont sound right pressure in the oil tank, it could explain the bike having any excuse to leak oil, i will have a look at the f2 and k1 to see how it is set up
Pete
UK Pete
Reply #38 on:
October 30, 2011, 10:04:55 PM »
Neil the bottom pipe goes to the crank case the top is to air, the rocker cover should end up in the air filter, on the f2 via a condensate trap
Pete
K2-K6
Reply #39 on:
October 31, 2011, 05:06:32 PM »
Niel, I haven't got my K2 where I live currently so can't check the exact layout for you.
I'll look at what info I've got to see if anything useful is there.
The oil tank on the bikes I've got have never had any pressure build-up in them even if you open them when running so something odd there. It's fairly conventional to vent from the top of many engines into the air filter to burn off any oil smoke that may be present.
K2-K6
Reply #40 on:
October 31, 2011, 07:51:01 PM »
Just unbolted a UK K6 oil tank to look at the back/conections, bottom pipe is definitely conected to back of gearbox casing and reaches up to the top inside so if overfull it would "leak" into the engine.
Cam box breather just goes to air down the back of the engine, it could be US spec that had vents into the airbox to reduce emmisions as any oil mist would be burnt by the engine via intake which ties in with them pushing manufacturers first into that scenario.
It does seem like you've got yours to over pressurise itself and should at some point be vented to atmosphere to avoid a build up of crankcase pressure.
It would make sense for both top of oil tank and top of cam cover to vent into the airbox to contain emmissionsas this would probably create a small negative pressure in the engine.
the-chauffeur
SOHC Member
Reply #41 on:
October 31, 2011, 10:10:00 PM »
Thanks gents.
Looking at the various fiches, the K2's are showing as having separate breather pipes from both the cam cover and the upper rear of the oil tank. Of course, both are long obsolete, but the fact there are 2 listed, and the airbox doesn't have the breather entry point the later models come with suggests to me that both vent to air - and the advice I got previously was wrong. I reckon K2's right about emissions, and that over the life of the model range, at least one of the breathers was connected to the airbox.
With that in mind, I've swapped the cam cover breather hose for a longer piece and put a small quantity of sponge in the trailing end; just enough to (hopefully) catch drips and stop anything nasty going up the wrong way. I've also done the same to the shorter piece, the top end of which I've left connected to the top oil tank connector.
I guess that with the new routing arrangement the crankcase pressure should be significantly reduced - and that I won't need to pray too hard that the JB Weld will put paid to the leak.
Here's hoping . . .
K2-K6
Reply #42 on:
October 31, 2011, 10:20:43 PM »
It'll be interesting to see how you get on and if it's leak free.
I was slightly puzzled that you had so many leaks compared to my experience hence the breather question.
Hopefully you've finally got all the bits sorted as they are nice to own.
Nigel.
the-chauffeur
SOHC Member
Reply #43 on:
November 02, 2011, 05:36:20 PM »
I'm still holding my breath and crossing my fingers . . .
. . . but I think I may have finally put paid to the oil leaks. Took the bike out for a 6-7 mile run today; not a major expedition, but enough to get the engine hot. No leaks and no squaks. Nuffink. I keep going out to the garage to see if it's dropped anything - force of habit - but so far, we're all good. After the best part of three year's work (on and off) I think I can maybe start relaxing about the engine.
I reckon that along with the filler, the massively reduced crankcase pressure levels won't trouble the top-to-bottom case seals any more. Which is a good thing. I'm still amazed at how close the JB Weld colour is to that of the cases. It's really, really close. As for the side covers, not even a hint of oil from them. And the 2.5mm o-ring plus a healthy smear of sealant has put paid to neutral switch leaks, too.
So thanks for all your help folks, although this isn't quite the last of it. It's time to start tidying the bits that don't look so, well, tidy and getting some (hopefully) worry-free enjoyment out of the bike . . .
Reply #44 on:
November 02, 2011, 06:02:56 PM »
Well done, my personal opinion is that 90% of you leaks was the crankcase pressure mate, ride it and enjoy it now----sez he now it's 'kin freezing and going white!!
3
4
CB750
