Author Topic: 750 F1 petrol tank problem  (Read 4312 times)
Offline sportsvan
« on: July 18, 2011, 09:48:31 PM »
my 78 f1 petrol tap is strange. the outlet for the fuel pipe comes out horizontally (sideways) this means that my fuel pipe is a nightmare to route.
WHY NOT GET THE CORRECT ONE THEN i hear someone say !
well i have 2 others which point downwards (the correct type as one is still on another 750 f1 tank) but the thread on my petrol tank is too small for them.
anyone got a solution ?
apart from that, i still hate honda 4 cylinder carbs! (well, i will until i finally sort mine out.)
ps anyone live in the worthing / horsham area ?
birth, school, work, death.
Re: 750 F1 petrol tank problem
« Reply #1 on: July 19, 2011, 09:08:44 AM »
The CB750F1 petrol tap outlet is vertical (points down), the CB750F2 tap outlet is horizontal, the tanks are identical apart from the spigot for the petrol tap which is a diferent diameter.
I found this out when the original tank on my F1 leaked and I replaced it with an F2 tank, I then had to source an F2 petrol tap (stopcock).
Here are the two together the F1 tap is at the top
Den
« Reply #2 on: July 19, 2011, 05:38:19 PM »
If its a 78 it can't be an F1 UNLESS it was in storage in a crate for 2 years+
Offline sportsvan
« Reply #3 on: July 19, 2011, 10:18:55 PM »
thanks for the replies chaps
1) glad to see you have an A65 SPITFIRE (is it a spitfire??) i have my 1970 royal star 500 which i bought for
« Reply #4 on: July 20, 2011, 08:33:03 AM »
My F2 is on an S plate, if yours has Comstar wheels, a black engine, double discs on the front it will be an F2, and my A65 is an A65R that I bought when I was 17 (quite a while ago !).
Here's the F2 page at CMSNL http://www.cmsnl.com/honda-cb750f2-supersport-england_model14689/partslist/
Den
Offline mick
« Reply #5 on: July 20, 2011, 01:11:27 PM »
Funnily enough i had a F1 that was on a S reg it must have been stood in a dealership before being registered?, cheers Mick.
« Reply #6 on: July 21, 2011, 07:09:59 AM »
Like I said, they wern't popular and quite a few stood in crates for 2-3 years before being registered. Still don't make it a 78, just a late reg 76
