SOHC.co.uk Forums > CB350/400
oil
SteveD CB500K0:
Oil threads are great!
If members = n, then opinions = (n+1) ;D
My four-penneth...
In the 70's, only mineral oil was available, so that was what they used.
You can use the modern equivalent (made by Rock Oil or Silkolene) or go for a standard semi-synth 10W-40 (I use Halfords...)
I believe that full synth may affect your wet clutch operation although I've no first hand experience and it may be an urban myth :)
Steve
ST1100:
--- Quote from: SteveD CB500F on November 28, 2011, 12:46:11 PM ---If members = n, then opinions = (n+1) ;D
--- End quote ---
LOL! ;D
--- Quote ---I believe that full synth may affect your wet clutch operation although I've no first hand experience and it may be an urban myth
--- End quote ---
Methinks the later ;) (using mentioned under sometimes harsh conditions in my touring rig since >200.000km...)
It however is an MC specific engine oil with friction additives for the clutch and increased shear resistance for the gear box.
Wouldn't dare to pour car oil into our precious ones... :'(
But here its about old engines, old school designs, different sintered alloys used for bearings/bushings...
What's the true deal there?
hairygit:
True deal? Stick with mineral oil, change it regularly, and the filter. 172,000 miles on my "winter" CB750F1, Tore the motor down a month ago to replace the camchain, no visible wear on the main bearings, cam towers or rockers, it gets ridden hard, is often thrashed mercilessly, and has NEVER broken down on me. It has the oil changed along with the filter every 2,000 miles ;D
K2-K6:
It's very hard to argue with keeping the oil in good condition and that would seem to be the the biggest influence in how it protects the engine whichever is your personal choice.
I think most of the decent quality oils available would be quite hard to tell much difference between to be honest if they are used within their operating range.
The engine tolerancing was origninally specified to run on 10w-40, so it would be sensible to start with that as base point unless any specific requirements have a higher priority.
It's very rare to see significant wear on most engine components with oil in good condition. There is always a contributing factor in my experience, like condition/dilution/quantity to promote failure.
matthewmosse:
I use Morris semi synthetic 10/40 fleet oil, I found comma semi synthetic sometimes led to cluch slip which was a shame as it was
Navigation
[0] Message Index
[*] Previous page
Go to full version
