SOHC.co.uk Forums > Recommended Sources for Parts and Services
Heat shrink tube for wiring
meerkat:
I've dealt with them for wiring bits as well. Postage was a bit steep but you have to consider that against availability elsewhere.
There's a copy of their shipping costs below. My order was for around
ST1100:
--- Quote from: kent400 on January 08, 2012, 12:32:59 PM ---Take a look at www.vintageconnections.com
--- End quote ---
IMHO another great supplier. Obtained an s-load of Honda style HP*L connector shells and crimps (CK-5 kits) from them for the refurb and customizing (EMT spec wiring) of my '94 ST1100 project, which are pretty unavail over here.
As for sleeving:
I've never seen shrink tubing used by Honda, only shiny, black PVC sleeving in various diameters; junctions (if not the whole harness) carefully wrapped with their highly adhesive PVC tape (when undoing this, you start to adore the 'zen art' this is performed by the jap assembly workers ;) ).
On delicate areas, like high amp leads closely bend around frame tubing (battery, starter wiring), a few inches of slit convoluted tube is added, again fixated with adhesive PVC tape.
Shrink tubed harness gets pretty stiff, won't flex/bend nicely around edges, thus risk of rubbing and leading to shorts...
UK Pete:
Thanks for the links everyone, seems like vintage connections is the place for the glossy black sleeving, i know it is not heat shrink but then i suppose the stuff i am replacing is not either, i am surpised that there is no one in the uk doing the stuff i searched the net and found nothing , so i will make an order with vintage connections
Pete
ST1100:
The PVC sleeving I'd ordered at Vehicle Wiring Products.UK comes in shiny black...
http://www.vehicle-wiring-products.eu/VWP-onlinestore/sleeving/sleeving.php
nomad:
Can anyone tell me if Durite PVC Sleeving is close to the OEM sleeving? I'm in the U.S. and am wondering if this stuff would be worth the shipping costs to the states... http://www.ebay.com/itm/DURITE-BLACK-PVC-SLEEVING-ELEC-HARNESSES-9mm-25M-/300645581442?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item45ffdf8282#ht_1116wt_1184
Navigation
[0] Message Index
[*] Previous page
Go to full version
