Author Topic: New member says Hi  (Read 6389 times)
Offline StPeter
New member says Hi
« on: June 15, 2012, 09:54:55 AM »
Greetings from Northamptonshire.
I'm just about to collect a CB500; It's registered 1975, in brown and mostly original apart from the pipes. Some cosmetic work required but it's a runner (it says here!). I've wanted one ever since I started biking back in the 70s so I'm looking forward to getting to grips with its wrinkles and foibles and will be unashamedly picking brains here to help me do it!
Thanks in advance, Pete
1975 CB500
Tiger 1050
Offline UK Pete
Re: New member says Hi
« Reply #1 on: June 15, 2012, 10:01:10 AM »
Hi Pete welcome to the forums
Pete
« Reply #2 on: June 15, 2012, 11:27:34 AM »
Welcome dont forgot any photos
Bitsa
Offline mickwinf
« Reply #3 on: June 15, 2012, 01:35:15 PM »
Hi Pete lots of help on here for us 500/4 owners, regards Mick
« Reply #4 on: June 15, 2012, 02:45:23 PM »
We can talk about Tigers here too if you like  :)
Offline florence
« Reply #5 on: June 15, 2012, 05:43:57 PM »
Another 500/4, hoorah!
Offline StPeter
« Reply #6 on: June 19, 2012, 11:13:43 PM »
Thanks for the welcome. Here's a pic of the new addition complete with puncture, leaky No 4 carb and (as I found out tonight) broken clutch pushrod. Apart from that, it's perfect.  ;)
P
1975 CB500
Tiger 1050
Offline florence
« Reply #7 on: June 21, 2012, 08:53:56 AM »
Very nice.  I had a leaking carb on mine.  I took off the float bowl and found that the float height was correct and the needle valve worked when I pushed the float up with my finger.  Mysterious; on closer inspection it turned out that the brass tube which comes up from the overflow pipe had a tiny crack in it and this was the cause of the leak.  A careful smear of araldite effected a perfect lasting cure.
Offline kifer
« Reply #8 on: June 21, 2012, 11:12:15 AM »
Welcome bike looks well tidy, you will have no problems getting it sorted lads on here know all there is to know good luck  :)
« Reply #9 on: June 21, 2012, 06:42:01 PM »
Looks great, I'm a bit partial to the CB500/4, great for swinging round lanes.
Offline StPeter
« Reply #10 on: June 21, 2012, 09:51:53 PM »
The bike's pretty photogenic - it has its tatty bits but the tank and side panel paintwork is really good. Just started the spending with new cables, levers, grips etc.
I've read threads here on the split overflow pipes and checked for that - I think the float height was wrong I've yet to hook them up to the tank again to check but I have my fingers crossed. I'm trying to keep my polimania in check but the sprocket cover does come up a treat . . .  8)
1975 CB500
Tiger 1050
« Reply #11 on: June 22, 2012, 07:27:39 AM »
Got me there.
Polimania?
Google says its a printing company in Poland...
Offline LesterPiglet
  • 1977 CB550F2
« Reply #12 on: June 22, 2012, 09:37:09 AM »
Got me there.
Polimania?
Polishing fetish. :)
Offline StPeter
« Reply #13 on: June 24, 2012, 12:52:16 AM »
There are recognisable signs which identify sufferers; shiny black fingernails on one hand and a black line running up the nose on to the forehead.
1975 CB500
Tiger 1050
Offline florence
« Reply #14 on: June 25, 2012, 10:33:40 AM »
I think I must have 'rustimania'.
